Whats the best all rounder performance road & track tyre
Old 25-03-2006, 09:18 PM
Johnny Knoxville
Johnny Knoxville's Avatar
Default Whats the best all rounder performance road & track tyre
What some 205/45/16 for my RST but don't know whats best?
What are you lot running?
I was going to get some Toyo R888 but there are a few bad storys about them when you hit a bit of standing water.
Old 25-03-2006, 09:34 PM
Jim Galbally
Jim Galbally's Avatar
i dont think you can go far wrong with the Eagle F1s
altho they offer simialr grip levels to the (cheaper) toyo proxies, (which wear faster) but considering you'll f**k the tyres on track in odd places, you might be better with the cheaper proxies.
i heard bad things about the new T1-R tho
i personally run Eagle F1s GS3s
Old 26-03-2006, 06:46 AM
Johnny Knoxville
I was told that Yoko's do some good one too?
Old 26-03-2006, 06:55 AM
simonc
simonc's Avatar
I have Yoko parada 2's on my 3dr cossie which i find are very good on the road & not bad for track either. At the end of the day you are never going to get a road tyre that is brilliant at both. I came to the conclusion that i'd be better off with 2 sets of wheels one for track & one for road, as said i use yoko's for road & on track if its raining, i have Toyo R888 fitted to another set of wheels for the track & the difference in using these on track in the dry or damp is like night & day compared to road tyres,so much grip Don't bother with them on the road though as they are noisey as hell & don't like standing water.
Simon.
Old 26-03-2006, 07:44 PM
Basky
Basky's Avatar
i use kuhmo ecsta road legal track tyres and had no probs
Old 26-03-2006, 07:56 PM
EIL132
EIL132's Avatar
Got Toyo proxies tr1's on mine and are excellent
Old 26-03-2006, 08:00 PM
le-claw
le-claw's Avatar
Thats odd cause mine have lasted 1800 miles cause i wanted to get rid of em....
WORSE TYRES i have ever had.....in 15 years of motoring...
the remoulds on the rex have more grip and feel LOL
Old 26-03-2006, 08:41 PM
marco polo
marco polo's Avatar
To be honest it's hard to have the best of both worlds but in the dry for road use and track use then i recommend Toyo R888 or Dunlop DJ01's/ DJ02's/ Mich sport cups /kumo's (meduim)
but these are not that good in the wet on any surface
you are better off the use road tyres on the road and use a set of slicks for the track all you have to get is a spare set of wheels job done
F1's are ok but they are just a road tyre and thats it nothing special
Marco
Old 26-03-2006, 08:53 PM
Basky
Basky's Avatar
did,nt realise that was you today marco wanted to ask you about your coilovers,iwas with ballbag
Old 27-03-2006, 11:13 AM
marco polo
marco polo's Avatar
Baskey LOL who is Ballbag Niel ?
I was talking to Neil for a while you couldn't miss me because my mullet was all over the shop
what do you want to ask i'll try and help you
if i can
marco
Old 27-03-2006, 09:44 PM
Basky
Basky's Avatar
just wanted to know if you had to mod your rear shocker mount at bottom to fit your billy,s and wot size are your bolts
had some tarmac spec billys all rosejointed and had to drill the mounts to 14mm top and bottom,and mod the bottom mount as the body of shocker was fouling the mount
i was with neil when you came, and i walked down to the pits with him when he was lining up
Old 27-03-2006, 09:47 PM
EIL132
EIL132's Avatar
Maybe your tracking is out
Old 27-03-2006, 09:52 PM
marco polo
marco polo's Avatar
Basky
all i had to do to mine , at the bottom of the traling arm when the rear shock sits all i did was slightly widen it for the rose joint
now on some tarmac rear billys they have an offset rose joint on the bottom one side is longer than the other and this is to stop it rubbbing on the inner arch so you get abit of clearance
as for the bolts i bought everything with the shocks as complete package
I have some tarmac rears here i'll take a few pics and show you the rose joints
gimme 10mins
Old 27-03-2006, 10:04 PM
marco polo
marco polo's Avatar
baskey
the top rose joint on the Bilstein should fit dead tight it just about fits
here is a pic
this is the top of the billy they are all the same
The Gravel Bilstien on my car have an off centerd rose joint at the bottom but these ones the rose joint aren't but they look like they will clear ,if not i can change these if needed no big deal
Marco
Old 27-03-2006, 10:08 PM
Basky
Basky's Avatar
cheers mate
but the issue is does the bottom of the shocker body catch your mounting bracket
Old 27-03-2006, 10:11 PM
marco polo
marco polo's Avatar
mounting bracket where abouts are they catching ?
Marco
Old 27-03-2006, 10:17 PM
Basky
Basky's Avatar
the bottom of the shocker body wont fit straiaght in the mounting
the bottom arm bracket fouls it ,and the bolt hole dosnt quite line up needs a few more mm can you cut the flange of on these mounts so it drops down
Old 27-03-2006, 10:21 PM
marco polo
marco polo's Avatar
Baskey
well in that case you might have to cut a step out of the trailing arm where the shocker sits
thats all i can say unless i see it
mine went straight on all i had to do with mine was widen it that was all
marco
Old 27-03-2006, 10:28 PM
Basky
Basky's Avatar
Old 27-03-2006, 10:30 PM
Basky
Basky's Avatar
thats wot ive done
but was curious about how yours fitted
it wont effect the strenght of the mount will it
also my rose joints dont have them spacers like your i had to get some stainless tube to make my own
Old 28-03-2006, 07:19 AM
marco polo
marco polo's Avatar
Baskey
can you take some pics you can send them to me e-mail address if you like , because you can cut and weld a little step in so you get clearance
marco
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
BRAM
08-09-2015 07:11 AM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Whats the best all rounder performance road & track tyre
