Help! DTC Codes.. Engine Management light on..
Old Mar 23, 2006 | 09:24 PM
OldDan's Avatar
OldDan
Default Help! DTC Codes.. Engine Management light on..
It's a 2001 Fiesta Zetec-S, with a de-cat, but does have a MIL illiminator kit on, had a bluefin handset onto the car and got back these two DTC codes.. obviously the reason why my engine management light was on..
P0460 : Fuel Tank Level Indicator Circ Error
Is the first one..
and..
P0171 : Sys too Lean (bank1)
Is the second..
Can anyone help? What the fook is going on, I assume these are related, i.e all to do with fueling?
Old Mar 23, 2006 | 10:49 PM
OldDan's Avatar
OldDan
Bump
Old Mar 23, 2006 | 10:58 PM
GARETH T's Avatar
GARETH T
P0460
check wiring, fuel level sensor ECM
p0171 system too lean
intake/exhaust leak, AIR system, MAF sensor, fuel pressure/pump, injectors, H02S
its neatly midnight mate,, so no need for the upset face,
Old Mar 23, 2006 | 11:04 PM
Doug's Avatar
Doug
Dan firstly ignore the fuel message it will always store that code unless you change the fuel tank sender card
P0171 Will relate to a fault on the upstream oxy sensor proberbly fooked
Regards Doug .
Old Mar 23, 2006 | 11:10 PM
OldDan's Avatar
OldDan
Cheers Lads
I'll have a look at her tomorrow.. fecking Fords. The fuel tank sender card, gone faulty I assume? How can two faults suddenly appear at once?
Is it something to be seriously worried about? Or, not "that" bad at all, i.e doesn't need desperate attention?
Thanks Doug and Gareth
Old Mar 23, 2006 | 11:12 PM
Doug's Avatar
Doug
Fuel tank message wont bring the EML on so ignor that one but get the oxy sensor checked as if fooked your engine will run lean and possibly melt a piston burn a valve in the long run .
Old Mar 23, 2006 | 11:13 PM
OldDan's Avatar
OldDan
OK, Thanks Doug
Old Mar 24, 2006 | 04:49 PM
GARETH T's Avatar
GARETH T
i cant believe he got an answer at midnight
Old Mar 24, 2006 | 05:50 PM
Doug's Avatar
Doug
Old Mar 28, 2006 | 08:40 PM
OldDan's Avatar
OldDan
Cheers Lads......
It turns out it was the HEGO Sensor..
Top work.
Old Mar 28, 2006 | 08:41 PM
Doug's Avatar
Doug
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
