Starting the saff this weekend
Old 23-03-2006, 08:27 PM
Rhys
Rhys's Avatar
Default Starting the saff this weekend
Right i got some cheap oil in it while it was stored so, im going to have to run it for a min or two then drain it out and put proper oil in before i used it. Do you think it would be ok to run it while on axle stands etc as seems pointless droping then having to jack it up agian loll. Cant see any problem, but just want a 2nd opinion
Old 23-03-2006, 08:38 PM
ballin
ballin's Avatar
be fine mate -- id be inclined to take it around the block tho for benefit of tyres, brakes, heat etc
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
It should be fine on the stands Rhys, aslong as its on them properly, i.e. not hangin off the chassis leg lol
Good luck mate, I have every faith it will start
Think he's gonna take it out a blast once he gets good oil in it!
Celebrate with a curry
Old 23-03-2006, 08:40 PM
Rhys
Rhys's Avatar
PMSL i dont need no encouragement to have a Curry Will let it tick over for a few mins on axles stands then change the oil to proper stuff. Then will be ready for MOT time should be fun
Old 23-03-2006, 08:43 PM
vroooom ptssssh
It Wasnt Me!
If your fussed, you could turn it over by hand a few times to get oil press up before starting, I cant see any harm in doing that as i know its a new engine and that!
Gotta agree, We need a curry appreciatin sticky
Old 23-03-2006, 09:17 PM
Rhys
Rhys's Avatar
Fookin agree about the curry topic PMSL!!!
Yeah will crank it over a fair few times with coil disconnected. Hopfully should start less tan 4k on the motor But knowing my luck that means fook all
Old 23-03-2006, 10:05 PM
vroooom ptssssh
It Wasnt Me!
Im off to find the curry thread! haha
Be best to crank with the plugs out and a master bar on the crank pulley, so it turns over slow without causing any dammage, but that's just being very cautious
Old 24-03-2006, 04:48 AM
Disabled Account
Disabled Account's Avatar
Rhys, with a car that has been laid up for a while I would do as follows:
Firstly make sure your battery is FULLY charged up (put it on trickle charge for 8 - 12 hours).
Then, before starting the engine I would remove the spark plugs, lift off the injector clips (so that injectors are not connected), then crank the engine over for a good while until you see decent oil pressure or until the oil light goes out.....engine should crank over easily with the spark plugs out
Only after doing all of the above would I refit the spark plugs / injector clips and run the engine.
Old 24-03-2006, 12:47 PM
Rhys
Rhys's Avatar
Cheers Doug didnt think about Removing the plugs
Old 24-03-2006, 12:53 PM
PT
PT's Avatar
you got any pics of your cossie mate. apart from sig lol
Old 24-03-2006, 12:55 PM
vroooom ptssssh
It Wasnt Me!
Dont be lazy and do it by hand, you'll not only burn off last nights curry, but you'll not need to disconnect the injectors (thus not breaking anything more than needs be its a cosworth remember )
Old 24-03-2006, 12:57 PM
Rhys
Rhys's Avatar
I have but they are sooooooooooo old. Will get new ones soon.
Here one from about 3 years ago.
Old 24-03-2006, 12:59 PM
PT
PT's Avatar
mk22door
49
26-03-2022 07:15 AM
CossieRich
30
08-09-2015 10:08 PM
martysmartie
06-09-2015 10:22 AM
Bailes1992
03-09-2015 02:17 PM
Adam-M
22
10-08-2015 10:46 AM
Quick Reply: Starting the saff this weekend
