Its official.......
Old 23-03-2006, 05:16 PM
Default Its official.......
...my brand new fuel pressure reg from Stu was wanked How lucky was i to have all the right gear to find this out or bye bye engine Got the gauge showing about 25psi idle and about 37psi with pipe off..gauge cant be accurate unless placing a metre or so away from the rail may be why....tried adjusting reg but it dont like to run on the correct gauge figures and on boost runs 9.8 on the AFR so back to factory setting and it now goes around 11.2 (previously it was 14 ) but i am only on 22psi so hoping she goes to around 11.5 afr on 32psi flat out ...I can not get CO at idle below 11.6 afr (adjusting via L8 co screw)...which is way too rich about 7% i think!...So work to continue...runs lovery though and shifts abit
What power do i have do you think at 22psi?
Oh and big up Stu...first class warranty service
Old 23-03-2006, 06:46 PM
POPEYE
FAIRY CAKE
POPEYE's Avatar
i deleted your bttt post so you didnt look a sad fooker phil
Old 23-03-2006, 06:47 PM
Cheers Pops...real mate you are
Old 23-03-2006, 07:07 PM
Look at all the nosey barstards looking but not replying
Old 23-03-2006, 07:10 PM
Billabong
Billabong's Avatar
Okay, just to keep you happy I'll reply
Personally, when changing something as critical as that, I'd have it done along with a checkup/setup.
Stu's service is excellent - as always, and short of testing all such parts (not that practical and would put parts prices through the roof!), could do no more Same as if you sold a set of injectors that turned out to be faulty.
Happy now?
On the CO front, are you sure the trim screw is actually working? You don't need me to tell you it's common for this to fail.
Old 23-03-2006, 07:16 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Nice one Phil, first faulty one ive ever seen!!
Old 23-03-2006, 09:56 PM
Bill......its deffo not fooked....i can adjust it down until its so rich it stalls!
Old 24-03-2006, 08:09 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Can youplease retro fit one to your mouth and adjust down to the same level?
Old 24-03-2006, 08:24 AM
DaveEscos
DaveEscos's Avatar
AFPMSL.. quote of the day so far to Rainbow
you get one less Chip Special @ central day for that Mike
Old 24-03-2006, 08:41 AM
Im sure im going to regret asking this
But WTF is a "Chip Special"?
Old 24-03-2006, 12:25 PM
I would suspect it means licked anal passage Chip
Just spoke to Karl and i have my instructions to sort everything from CO to fuel pressure to FAST ..
May i add too that i have had NO trouble whatsoever getting hold of him Great customer service on what is an off the shelf map to a complete novice
Old 24-03-2006, 12:26 PM
DaveEscos
DaveEscos's Avatar
search for the Central Day target thread mate
Old 24-03-2006, 12:43 PM
Sticky.
Sticky.'s Avatar
Could have been costly
Well done MSD for sorting it out
