Coil pack /revcounter prob
Old 22-03-2006, 02:33 PM
costech
costech's Avatar
Default Coil pack /revcounter prob
Any news on a fix for the revcounter problem on the coilpack conversion.
So I could buy one
Old 22-03-2006, 02:56 PM
foreigneRS
Testing the future
foreigneRS's Avatar
costech
what rev counter do you have, and how are driving the coilpack?
Old 22-03-2006, 03:07 PM
costech
costech's Avatar
I dont have a coilpack yet, i mailed stu for one but he said that he dident want to sell on before the revcounter problem was fixed.
That´s why i´m asking because i whant one for my winter car
Old 22-03-2006, 03:22 PM
foreigneRS
Testing the future
foreigneRS's Avatar
what winter car is it? what rev counter?
Old 23-03-2006, 05:40 AM
costech
costech's Avatar
O sorry it´s a 4x4 Sierra Cosworth
I have a Stack revcounter so for me it´s not a problem with
the counter signal, the problem is that stu don´t want to sell
the driver board before it works properly.
I understand why he wants to sort it out first, he´s
only selling top stuff
Old 23-03-2006, 07:22 AM
foreigneRS
Testing the future
foreigneRS's Avatar
oh right. yeah, with a stack you'll have no problem.
what i don't quite understand is how anyone expects a fix to come from SECS for this rev counter issue?
the coilpack driver board just splits the pulse to the amplifier in 2, but the rev counter on a sierra cosworth is driven by the green wire from the coil. if that only ever comes from 1 coil in a pair, it can only ever be half as frequent, so the rev counter will show half speed.
the modification will surely have to be done on the rev counter, nothing to do with the coilpack driver board?
Old 23-03-2006, 07:59 AM
Dave Henshall
Dave Henshall's Avatar
he has incorporated some circuitry onto the coilpack driver board to drive the rev counter aswell, this has an extra wire that runs through the new sub loom and effectively connects to the green wire. it works aswell as long as the car is not on boost, its only then that the problems start, with the first revisoin of boards p8's were affected the worst but only some, not all, i had mine swapped to a rev 2 board for free by stu when mine stopped working (but in fact it wasnt the board at all, it was the tdc sensor it turned out) and the later baords are much better, but still read about 700 rpm low at the top end.....
im sure he will sort it, its just a matter of time... and as it doesnt affect the running of my car i'm not too bothered, would just like it to be right eventually...
Old 23-03-2006, 08:14 AM
foreigneRS
Testing the future
foreigneRS's Avatar
oh right dave. i get it now
i didn't know that the driver board also connected to the rev counter instead of the usual place on the coil
Old 23-03-2006, 08:18 AM
Dave Henshall
yep but as kjc has found, it may well be worth reconnecting the green wire to read half what it should from one side of the coilpack and fit a later coilpack xr3i rev counter, as this solves the problem, albeit a bit more work and expense, but its right then...
Old 23-03-2006, 08:42 AM
Azrael
Azrael's Avatar
What about connecting the wire to both sides somehow? Impossible?
Old 23-03-2006, 09:02 AM
Does seem like a simple solution that one!
Couple of diodes to make sure the signal only goes one way and jobs a good'un
But im sure there must be more to it than that or they would have done it ages ago!
Old 23-03-2006, 09:04 AM
Azrael
Azrael's Avatar
chip-3door I know nearly nothing about such electronics but if it isn't possible someone would know why....
Old 23-03-2006, 09:09 AM
Im sure Stu or SECS will be along later to point out something about that idea that we will feel embarssed for not thinking of ourselves mate
Old 23-03-2006, 09:15 AM
Azrael
Azrael's Avatar
chip-3door I'm embarrassed enough with my foolishness about my car in last 3 years, more won't make much difference
I have a very talented friend working in electronics. He custom makes lotts of different circutry. If there was interest for a fix to that and some documentation of the problem he could probably produce something easily.
Old 23-03-2006, 09:19 AM
foreigneRS
Testing the future
foreigneRS's Avatar
that has been tried. there's been a couple of topics about it.
as far as i am concerned, i will be leaving the green wire connected to one coil, and modifying my rev counter to double up the speed.
Old 23-03-2006, 09:22 AM
Azrael
Azrael's Avatar
foreigneRS so you stay in Cossie world after all? I remember that you were to sell up...
Old 23-03-2006, 10:39 AM
foreigneRS
Testing the future
foreigneRS's Avatar
Azrael sadly not, i will be selling up.
but that's something that i plan to do to the car before selling it. more out of interest than adding value though i guess.
Old 23-03-2006, 10:44 AM
Azrael
Azrael's Avatar
I see. Sad anyway :-(
Old 23-03-2006, 10:52 AM
foreigneRS
Testing the future
foreigneRS's Avatar
i will still have a 1/3rd share in a cossie, so all is not lost. Maybe I would buy the other 2/3 after getting a house
Old 23-03-2006, 10:54 AM
Azrael
Azrael's Avatar
foreigneRS good plan
Shame you don't own some blown up LHD Escos :-/
Old 23-03-2006, 11:00 AM
Dave Henshall
yep, the 2 wires with diodes works on some cars, but not all, apparently secs said there are times when both coils are energised at high engines speeds, which would leave no signal to the rev counter using this method
Old 23-03-2006, 11:57 AM
foreigneRS
Testing the future
foreigneRS's Avatar
you would imagine that there should be a time when both coils are energised - otherwise, what's the point of 2 coils?
Old 23-03-2006, 12:36 PM
Dave Henshall
Old 24-03-2006, 06:42 AM
costech
costech's Avatar
Another guestion does the secs coilpack driverboard have
builtin dwell control or does it just split the trigger signal in
two and use "intellegent" amplifiers to control dwell ?
Old 24-03-2006, 07:11 AM
the original
the original's Avatar
my secs board is a great product, but i have looked and even at high rpm it does not charge both coils at once which i believed should be one of the main reasons for designing such a system
Old 24-03-2006, 07:46 AM
Dave Henshall
aparently is does have active dwell.. have a read on the post on stus sig
Old 24-03-2006, 08:04 AM
the original
by active dwell i normally take that to mean fixed dwell time, or slightly longer dwell at high rpm/boost, which is 'active' compared to points and coil (percentage dwell)
on my secs board i'm getting around 10ms at 1000rpm, 10ms at 3000rpm but only 2ms at 6200rpm
must stress no misfires or problems though, thought at first maybe the amps had some circuitry but looks like the spark is triggered on the falling edge
Old 24-03-2006, 08:10 AM
Garage19
Garage19's Avatar
This is the circuit i have always used to drive a tacho from a ford coil pack. Has always worked fine so far.
Old 24-03-2006, 08:26 AM
Dave Henshall
dunno m8, would have to ask SECS....
the diagram above works for some people on some cars but not others, escos rev counters in particular dont seem to work with that setup
Old 24-03-2006, 08:40 AM
Ryan
Ryan's Avatar
as said escort cosworth clocks dont like this setup
Old 24-03-2006, 09:35 AM
jon@work
jon@work's Avatar
if the circuit above doesn't work, try adding a 4.7K ohm 3W resistor between the zener output and earth - worked for a friend 2 weeks ago on another Ford tacho that didn't like the basic circuit - about 35 pence from RS.
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
Quick Reply: Coil pack /revcounter prob
