cossie fuel pump
cossie fuel pump
Can anyone help me, ive just got a cossie fuel pump for my fiesta rs turbo and ive dropped the fuel tank and taken out the old fuel pump, but is there some sort of connector i need to make it fit cus it isnt a straight swap unless theres a bit missing from the cossie pump!
Also ive just brought second hand green injectors which were on a stage 3 saph cossie for bout 3 months. Can i put them straight in or should i buy new o-rings, seals etc.
cheers.
cheers.
hold on, what ECU are you using? you cant use cossie greens with EEC-IV! you'd need some form of aftermarket management.
also you should use new o-rings etc when changing injectors
what exactly are you trying to acheive as i think someone's been giving you duff tuning advise if theyve told you to put greens on a fiesta RST and wanna make sure you've got all your facts right etc
i thought about the internal/external thing but didnt wanna say anything as it'd be a bit obvious when looking at them side by side that theyre completely different
cossie09
14-09-2015 04:21 PM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
