how do you setup vernier pulleys for a zetec turbo then? :)
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
just won those on fleabay and just wonderd if anyone had set any vernier pulleys up on a ZT before so i can set them up first time (ish)
i think i read some where zetec turbo's like the exhaust cam advancing a bit but not shure about the inlet cam (im probably talking bollocks here)
im running 130ps blacktop cams and omex so the map can be tweaked but i dont think changing the pulleys is going to efect the map that much i hope
Proven Legendary Status
The same way you set any vernier up.
Get true TDC, Stick the belt on, then rotate the engine crank the number of degrees the cam manufacturer state. Using a gauge. Then adjust the vernier so you have maximum lift on the cam using a DTI.
"Generally" cars feel better with the inlet cam slightly advanced than retarted, they feel "perkier" But don't go doing it by eye. Get a the gauges out.
ahh i read somwhere that the zetecs run retarded ex cams for emissions
so how much difference do you think it will make wuth the pully's set up properly?
bit off the topic but how good are the zetec turbo cams from cylender head developments in birmingham then?
Set it all up accurately, and you'll get the maximum benefit from the cams. I have no idea how good those cams are though. TBH I'd not go for any unknown makes, only Piper/Kent or similar.
But like I say, go for what the manufacturers state, and it'll be as good as you can get it.
As for retarding the exhaust cam for emiisions. I couldnt say either way.
Are you talking about the possible use of other specification standard equipment cams in a turbo zetec?
I am currently mapping all the profiles and timings of the standard zetec cams available to come up with a decent solution for turbo cams. I may have newman grind or re-grind some to my spec.
I will let you know how i get on and what i find.
Doug.
Doug.
