whats a big wing sump
Football Cwazy
it's where extra capacity is added to the sump to increase the amount of oil it will hold,
this makes oil surge less likely during heavy braking/cornering ( where the oil surges to one side of the sump and leaves the crank running dry)
also helps keep oil temps lower too i beleive
only downside is oil changes cost more.
Martin Hadland makes them i think, and can probably do any capacity required (extra 1 litre,2litre etc)_
how are ur wings done?
as this is my main concern for changing for a standard baffle.
are the sides of your sump drilled to slow the flow to the wings?
Originally Posted by The Usual Suspect
are big winged sumps only needed on transversly mounted engines? as ive never seen one on cvh,s ect,
thanks
thanks
the finis code was 9090061, i got pic too,
i don't think the local ford dealer would get one tho, lol
No1 Blower.
thanks
thanks
