Multilayer steel gasket help pleeeeease
I got a 6 layer steel head gasket, and i think some oil has got in between the layers. Clean oil mind, not old oil.
Will it be ok to torque the head down with the gasket as it is? Or will the oil boil inside the layers and fuck it up?
cheers
cheers
Originally Posted by cossierich330
As Stu said SPence dry it out properly or get another one.
6 layers is a hefty gasket.
Its a Z20LET gasket modified to fit C20LET/XE blocks, the rivets have been drilled out so the layers are all seperate from each other.
Its a shame i have to dismantle it again, i had it lined up perfectly
Cheers Stu + Rich, Much appreciated
doh, posting at the same time!
As its a ZLET one, just take it apart give it a good wipe, and put it back together, jobs a goodun
Oh i been meaning to ask you something aswell, you just not been about. What's Rich's Ebay name, is it 225bigrichturbo?
Also, still owe you for that bloody inlet. Its been ages, you must be well pissed with me
Originally Posted by R4N S S
can you reuse a metal WRC multi layer gasket?
and how reuseable are they once they have been taken off?
Ive reused a cometic MLS one, but it had only been clamped down, not actually run when i took it apart.
Well Stu recently took a customers engine apart due to a faulty oil pump he was supplied, and he posted on here that he had to replace the gasket, so he obviously beleives that you cant reuse them.
I heard that cometic gaskets can be reused, I thought that was the whole point of a race/rally gasket? The point being that if there are any problems you can whip the head off, have a look, and replace the gasket.
Personally, for £100 that the cometic gaskets cost, i'd be re-using them
Rich, Ello lol I thought it might have been you that i purchased the LET fuel rail off on ebay.
Also, whilst i'm here Chip & Rich, you wouldn't happen to have a photo of the top of a LET with the turbo plastic cover removed would you? Just need to get a good idea how i've set mine up if its right or not.
ta
ta
Spence you goon. I am not the Rich you bought anything from on Ebay. im the usual Rich you have always spoken to on MSN and go to the weatherspoons in sutton on a thursday (weel we used to). Will have to get that going again. twas good fun
I tried speaking to you on MSN loads of times, but you never answer
Still got your chrismas message on there too
Chip, I am still banned yes, and always will be I was never childish, its that lot of twats that got my goat and made me look childish.
Can't you see the improvement sincei been here
have just msn's you actually Spence. I now have broadband at home so am on it far more. i used to leave msn open all w/e on the work pc but never chnge my status. Sorry for confusing you. It didnt take much
Spence, yes there does seem to have been an improvement on MIG a bit since you moved to here.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
