Whats the maximum safe
Whats the maximum safe boost to run on a std 2wd engine with grp A gasket & stg 3 conversion ?
Peaks @ 25-26 and holds 22 psi
Regards Doug .
Regards Doug .
My experience with fibrous gaskets is that when you start running lots of boost, they still last ok initially but its a cumulative effect, and other time they get slowly hammered back by the boost (well the PCP created from the boost) and end up out of shape over a period of time.
The further you go with the boost, the quicker that happens.
I dont know specific numbers of miles for any given boost amount on the YB though im afraid.
Cheers Chiperooooooo although i didn't understand a fooking word of what you just said JOKE m8 just wanna get some input see if it will take more boost for a track day or leave it where it is TBH its a bit of a shit now at the boost its running tends to let the arse go
Originally Posted by Stu @ M Developments
Your current limit isnt the gasket Doug its the 803s.
If you want to pop up for an evening, i can set her to the maximum allowable on your setup if you like... squeeze a little more out, and in return, the night out afterwarts is on you. Waddaya say?
Lol That sounds a bang on idea treacle Ill try and sort for this weekend p.s. got a spare sofa / bed hotels are fooking dear in pool and its out of season lol
cossirob
16-09-2015 07:39 PM
