Steering wheel shaking on braking but its not the discs HELP
Hello as above its starting to piss me off, only does it a little bit on light braking. i have changed the all the brakes but its still the same. Is there any thing else it could be
Rich
Rich
Hi mate,
if you are sure the brakes are all fine and you have this vibration coming from the front of the car, then you ought to be looking at the front track control arm bushes or bottom ball joints. If these ok then check track rod ends for wear.
CheeRS, Mike.
CheeRS, Mike.
have you checked the hubs as they warp,bet it does it around 50mph my one does it havnt got round to do it yet had new discs and pads and bushes found out the hub had some run out.
JoeyBoyden
04-01-2024 02:36 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
