Turbosport.net clutch/ flywheel?
Old 22-02-2018, 05:34 PM
5hane
5hane's Avatar
Default Turbosport.net clutch/ flywheel?
Hello,
wondering if anyone has any experience with the turbosport.net lightweight clutch/ flywheel combinations?
The cars main purpose is to be used for track days, but i will want to drive to and from the track. As well as Nurburgring trips, they weigh 2.5 kg which is very light compared to standard.
They seem to be very good value, and whilst my engine is apart i would like to get the crank/ clutch and front pulley balanced, so seems a good time to invest!
Thanks!
Old 22-02-2018, 05:41 PM
Caddyshack
Caddyshack's Avatar
Every time I have asked Mark Shead about light flywheels he only ever says 2wd standard or early escos 4x4 which leads me to believe you don't need the lighter ones at all. My 2.2 stroker will run 8000rpm max I think and 630bhp, he still says the same flywheel
Old 22-02-2018, 05:52 PM
5hane
5hane's Avatar
Fair enough! cant argue with that!
What clutch will you be using?
Old 22-02-2018, 07:00 PM
Caddyshack
Caddyshack's Avatar
I have the helix high clam setup from Reyland
Old 22-02-2018, 08:20 PM
Adam-M
Adam-M's Avatar
I think cars with lightweight flywheels drive horrible
Old 22-02-2018, 09:14 PM
cossynut2
cossynut2's Avatar
I have had no issues with my lightened flywheel/Helix 6 paddle clutch set up.
My 2wd Saff drives/accelerates nicely.
What do you mean by drives horrible?
Old 23-02-2018, 09:00 AM
cossie2
cossie2's Avatar
true...had one with twin plate clutch set up,,all the time you need to rev it up...it is good for track but if you use it daily it is not good
Old 23-02-2018, 09:14 AM
Adam-M
Adam-M's Avatar
Is yours a lightweight one like on the post or a lightened standard flywheel I.e still a heavy bugger but had a kilo or two shaved off?
I think pulling away and gear changes aren’t smooth and need lots or revs and cars seem to bog down easier on launch as less inertia.
Old 23-02-2018, 09:58 PM
cossynut2
cossynut2's Avatar
Mine is a Reyland one, lightened standard one. If you came for a drive in mine you would see it has no downsides.
Old 24-02-2018, 06:55 AM
Caddyshack
Caddyshack's Avatar
The Reyland ones are 7.7kg and 5kg, the turbosport one (pictured)is 2.3k but they do a heavier one, the standard is around 11kg to 12kg
Old 24-02-2018, 09:00 AM
cossie2
cossie2's Avatar
7.7 kg is more than good,right now i have that one,before i had 4.5 kg....bad decision..
Old 24-02-2018, 09:34 AM
cossynut2
cossynut2's Avatar
I can't remember which one I got from Reyland but it certainly works well with my set-up.
Old 24-02-2018, 11:17 AM
Caddyshack
Caddyshack's Avatar
That's good to know, I think the key is keeping some weight on there and not going silly with it.
Old 25-02-2018, 10:25 PM
markk
markk's Avatar
While the mass is important, what is more important is the location of the mass.
No one can argue with physics (though they probably will on this site).
F=ma.
If you want to accelerate the mass plays a huge part. The same goes for negative aceleration.
Why do people lighten vehicle weight again?
turbotrev (26-02-2018)
Old 26-02-2018, 05:26 PM
Caddyshack
Caddyshack's Avatar
F=ma.
So, based on experience what weight would you put on?
Totally on board with adding lightness (currently swapping every bolt I can for titanium)
Old 26-02-2018, 05:34 PM
markk
markk's Avatar
[QUOTE=Caddyshack;6763787]So, based on experience what weight would you put on?<br /><br />Totally on board with adding lightness (currently swapping every bolt I can for titanium)[\quote]
All depends on application. For me, very little traffic work, but still behaves extremely well on the rally car at less that 3kg plus twin plate clutch. Engine acceleration counts. On a road car, pleasant manners are needed. Maximum aceleration isn't always needed. The MoI can be on the outside of the flywheel and still be lowish weight.Once at higher engine speeds the MoI becomes less important.I'd be going half way or std weight for a car I had to drive. For a car I drive because i want to then its light everytime.
Caddyshack (26-02-2018)
Old 26-02-2018, 06:04 PM
turbotrev
turbotrev's Avatar
That’s fine with a 240mm standard size clutch but with the twin plate clutches most are a smaller size hence the lighter smaller flywheel
How can lighter be worse?
Cheers Paul
Old 26-02-2018, 06:06 PM
Caddyshack
Caddyshack's Avatar
A car runs a flywheel for a reason and it's not just to mount a clutch on.
Old 26-02-2018, 06:09 PM
turbotrev
turbotrev's Avatar
I know.
But how is lighter worse?
I had a lightweight ttv flywheel in my car and it was no worse than a standard flywheel
Plus side was it was over half the weight and will put less stress on the crank esp at high revs
Cheers Paul
Old 26-02-2018, 06:22 PM
Caddyshack
Caddyshack's Avatar
Yeah, I think half may be the limit before the drivability becomes a problem. I drove a mates 911 RSR with a very light flywheel and on a hill start it just wanted to stall or fry the clutch....I think that is the problem with going too light. I suspect anything under 5kg might become a pain in traffic
Old 26-02-2018, 06:26 PM
markk
markk's Avatar
My triple plate with a 2.5kg was no bother. But, i knew how to drive it.
My mum would struggle though. Change it for a heavy flywheel and my mum could drive it.
Thats the difference.
Old 26-02-2018, 06:30 PM
Caddyshack
Caddyshack's Avatar
That probably sums it up.
There is a nice satisfaction from rev matching, sustained changes, a double de clutch and smooth driving but to the average muggle it would be a pain if you HAD to drive that way although if you can it is enjoyable even on an everyday car.
Old 26-02-2018, 06:45 PM
Mark Shead
Mark Shead's Avatar
Originally Posted by turbotrev
I know.
Cheers Paul
The flywheel stores the energy through its weight a YB is hopeless with a light weight flywheel unless it is on very short gearing which lowers 1sth gear so you can pull away
Mark
Old 26-02-2018, 07:03 PM
turbotrev
turbotrev's Avatar
But in reality does the driveability matter that much?
Especially with paddle clutches anyway, they all pull away horrible.
And also for most people these ain’t daily drivers, these cars cover a few thousand miles tops and are normally tuned up hence needing race style clutches... reliability over driveability??
Cheers Paul
Old 26-02-2018, 07:04 PM
turbotrev
turbotrev's Avatar
Mark
I never noticed any difference when changing to a lightweight wheel though?
And why would twin/triple plate clutches come with such lightweight flywheels?
Cheers Paul
Old 26-02-2018, 07:09 PM
Caddyshack
Caddyshack's Avatar
When I drive a car for fun it has to be nice to drive.
As you say they pull away horrible, maybe that's the flywheel weight being the problem?
I don't think your flywheel is as light Trev, as said half standard is probably the limit but I suspect 2-3kg might ruin a road car.
I have a paddle on normal flywheel and that is like a standard car to drive, I just try not to slip it as I think that is not good for them.
Old 26-02-2018, 07:17 PM
Mark Shead
Mark Shead's Avatar
Cheers Paul
It was not light then lol.
Mark
Old 26-02-2018, 09:21 PM
turbotrev
turbotrev's Avatar
I meant as in every paddle clutch, they all judder when you pull away and are moving slow in traffic.
Mine was no worse after fitting a really light flywheel.
But we all need this race clutches fitting due to the rise in hp.
It’s nver gonna drive like a nice normal road car.
My old ttv flywheel was 4.6kgs and felt the same as a standard flywheel.
You can’t compare a race paddle clutch to a normal organic road car clutch, of course they are gonna be different when pulling away in first gear.
Cheers Paul
Old 26-02-2018, 09:22 PM
turbotrev
turbotrev's Avatar
Mark
It was Mark, 4.6 kilos, More than half a standard flywheel weigh.
That’s gotta be kinder to the crank and better for pick up being less rotation mass?
I can’t see a downside from my own experience using one for two years
Cheers Paul
Old 26-02-2018, 09:23 PM
markk
markk's Avatar
4.6 kilos.
That’s gotta be kinder to the crank being less rotation mass.
Cheers Paul
makes no difference to the crank. Its a balanced mass.
Old 26-02-2018, 09:26 PM
turbotrev
turbotrev's Avatar
But a lot less of a rotational mass being my point.
Like for one of the reasons people run alloy cam pulleys
Cheers Paul
Old 26-02-2018, 09:52 PM
markk
markk's Avatar
Cheers Paul
lol, alloy cam pulleys, yes people really run them to reduce inertia. Bit of bling maybe, very little other reasons.
Mass only affects the rate of aceleration whether that be positive or negative. If it was out of balance it would affect the crank.
Old 26-02-2018, 09:59 PM
turbotrev
turbotrev's Avatar
But a light flywheel would reduce inertia also so that can only be a good thing??
Cheers Paul
Old 27-02-2018, 07:19 AM
Adam-M
Adam-M's Avatar
There no doubt that there’s a performance gain I.e revs faster, totally beleive they can make it easier to bog down ( Subaru’s have flywheels like brake discs and are worst car to launch)
My civic type r has a factory fitted lightweight flywheel and pulling and away and gear changes are a pain to get right and smooth.
If it was a track car then wouldn’t bother me
Old 27-02-2018, 04:13 PM
turbospud1
turbospud1's Avatar
it certainly makes it rev faster,drives just like markk describes
got that setup,ap 7 1/4 twin plate paddle clutch
Old 27-02-2018, 05:45 PM
cossynut2
cossynut2's Avatar
Cheers Paul
I am fitting a concentric hydraulic clutch conversion on my 2wd Saff which has a lightened flywheel and a Helix 6 paddle clutch. Supposed to make quite a difference to the feel of the clutch.
turbotrev (28-02-2018)
Old 27-02-2018, 06:41 PM
Caddyshack
Caddyshack's Avatar
I have a helix 6 with Reyland high clamp, it is a bit heavier than my 1.9gti but not bad for a 500lbft capable system, I had the centre push then swapped to side push.
Old 28-02-2018, 01:04 PM
turbotrev
turbotrev's Avatar
Because I’m upping the engine power more this year I too will be going twin plate with a light flywheel and centre push hyd clutch setup.
Don’t think I’ll risk the turbosport one though, I’ll prob go ap
Cheers Paul
ricky_3dr
18
09-01-2006 03:33 PM
Turbo lag
15
20-03-2005 12:57 PM
GAZ W
17
16-12-2004 10:41 PM
RS2000CUSTOM
21-07-2004 07:26 AM
kay2
27-04-2004 08:44 AM
Quick Reply: Turbosport.net clutch/ flywheel?
