AP's under Comp 18's
Going to order up bells/rotors soon and need to know the biggest disc size I can use under new Comp Mo 1881's 18x8
I'm receiving conflicting info,
362 x 32 under old style Comp MO 18's will work
378 x 32 under under 18 Rota's? surely can't fit unless they are 19's
Justin's B13 3dr (Fast Ford front cover) 362 x 32 under RL7 17's? surely can't fit unless they are 18's
Looking like I'll be going 362, same as Kev's (K5OSY) as they are close
I also have 4x4 with 18inch comp's and AP brakes from Reyland 362mm AP Racing 6-pot CP7040 calipers.
I actually needed to mill down the bracket 1mm because the clearance was almost nothing.
On my 2wd is the same brake set but this fits perfectly under 17inch because the brakes are more on the inside of the rim where is more space.
2wd and 4x4 is already different.
I see, mine is 4wd so looks like ill be going 362's
I have heard the Reyland brackets are close, maybe have to get them elsewhere as I don't want to be machining new parts down for the price of them
Cossy Mike (13-12-2015)
What I'd do is bin the 18's and fit 17's - 18's make a Sapphire drive horribly. Plus they catch all 4 arches so you'll need to address that.
Not on a Sapphire with Mos. Biggest you can get is 362 on CP5555 calipers.
Paul_RS (08-03-2015)
Cossy Mike (09-03-2015)
Just waiting for Mark to reply from MT motorsport
Does anyone know the part numbers or a link to the genuine AP 362 x 32 j-hooks?
It's coming up 4 options on there website
Thanks for all the reply's, big help
PM Mark King on here - he just bought some AP discs and may be able to get you a part no.
That's an Escort
You've no mission of getting that size disc on a Sapphire.
CP5772-168 RH
CP5772-168 LH
I sent a message to MT to price them up but apparently he took offence as I sent it on a Sunday.......I'll be getting the stuff from Martin at Reyland, at least he has the decency to contact you back.
I've since found them Paul, cost is £402.11 each
CP5772-168 RH
CP5772-168 LH
CP5772-168 RH
CP5772-168 LH
Cossy Mike (13-03-2015)
KSA-Cossie (14-03-2015)
Wheel offset is totally different
Same brakes will hit a wheel on a Sapphire as the caliper face touches the back of the wheel's spokes. The lower offset on an Escort allows way more clearance. 363mm discs are the biggest you can fit on a Sapphire with a CP5555 caliper. You can do 378mm on an Escort with the same caliper and wheels.
Paul_RS (16-03-2015)
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
