Chip Id help
13-03-2015, 07:14 PM
Chip Id help
Can anyone shed some light on what chip has these numbers on it.
PTS SAP ST3 ?
I dont have a pic but its in a L6 ecu if that helps ?
14-03-2015, 08:38 PM
Performance Turbo Systems possibly. Not sure if they are still going.
16-03-2015, 09:13 AM
Live long and prosper!!
As u said performance turbo systems.
Stage 3 saff
So 803 green injectors
Level 6 ecu
3 bar map.
Prob std turbo.
16-03-2015, 04:41 PM
Awesome thanks guys.
You think it would work on a 3dr that already has 803's, 3bar and a t34 ?
16-03-2015, 04:54 PM
Quote:
Originally Posted by
cromb2555
Yes it will work BUT be aware that a T34 will flow more air. So to be sure have it set up on the rollers.
if it runs lean IT CAN DESTROY a engine in minutes.
Also the 3dr will need a level 6 ecu
16-03-2015, 05:20 PM
yeah cool thanks. the chip is already in an L6 ecu and my car also has an L6 ecu, so it should be a straight swap and a rolling road map.
16-03-2015, 05:43 PM
cromb2555
If you are mapping it the chip you have is irrelevant as the data will be over written.
tankybaby66
06-02-2016 02:24 PM
Fiddy
21
29-09-2015 06:10 PM
A.t.p
29-09-2015 05:04 PM
RSmark84
13-09-2015 01:29 PM
