Sapphire sunroof blind removal
cossie fan (unluckerly)
How do you mean hole assembly?
Do you mean drop the lot down into the car with the head linner out or glass out then remove the blind out the car
Resident Wrestling Legend
there are 2 screws inside by the winder too and then the whole sunroof assembly comes out
be careful not to scratch the roof and it's always wise to put some heavy toweling on the front as the whole thing slides out over the windscreen and is about 3.5 foot long in total
it's also worth while getting a mate to lend a hand so you can pull it out from either side rather than standing on the bonnet
There is a sequence to do it iirc you start with the sunroof open and work your way to the front ending up with the sunroof closed and screws out, then remove the winder handle otherwise when your having to move the sunroof to tilt it to get the screws out all the cables fuck up.
If you don't want the blind anymore I'd go the easy way snip snip snip![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
cos your bound to find something upsetting if you take the cassette out, and getting it back in is a twat cos it's closed and you need it open to put screws back in.
Ps one of my snap on batteries took a charge the other day!! Seems they don't like being cold
It's a bit of a pig job, I replaced the one in my car as the original one was filthy, needed a clean one after I re-trimmed my head lining,
To get the sunroof out as said remove all screws and winder,iirc the roof has to be fully opened, once all fixings are out of the way the whole mechanism slides out forward towards the bonnet/windscreen, the runners will appear as you go and make sure you've taped up the roof forward of the sunroof in case you scratch the paint![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Luciano
Luciano
Luciano
Luciano
But it's been confirmed to be shit job at best.
Back in black!
Ive just this minute come in from removing my whole sunroof had it out in about 5 mins although this one wont be refitted as its fucking rotten![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
anyway this is what i did
Open sunroof
Remove all the screws from the edge
Close roof
lift/push glass from inside and out it slides
Then you get pissed off because of all the rot you've just found and come in and try and find a new sunroof
Open sunroof
Close roof
Ha ha sounds a right arse!
I've just got mine back from having inner and outer seals and a few odd bits on the floor done so don't need to find any more rust lol.
I painted it black in place in the end
ive done mine a few times now and its a piece of piss imo. i can remove the whole thing in about half hour, its just alot easier with two people .
and im now in the process of fitting an electric roof in my saff,if you want to just take the glass out it can be done in situe which is a little harder to do , taking the sun roof out complete it depends why you want to take out the sun roof let me know and i can take a photo or two on what the easiest way is
I just took mine out
mine was easy this time because all the screws etc were mint
won't be going back in though got different ideas.
Did it ending with sunroof closed push it up and out, only issue is the winder not hitting the roof when pulling.
Open sunroof
Close roof
Then you get pissed off because of all the rot you've just found and come in and try and find a new sunroof![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Open sunroof
Close roof
got to check first though as i may have binned it
Live long and prosper!!
thanks
Fudgey
17-09-2015 01:06 PM
Si B
12-09-2015 06:49 AM
