Gearbox oil & diff oil
Got a 88 reg 2WD sapphire and havent changed either of my diff oil or gearbox oil since i had the car.
Just wondered what grade and make of oil people use.
Thanks
Thanks
Hi
Thanks for that. I would go for a good ATF, like Amsoil ATF, Fuchs ATF 5000 or Redline D4 in the gearbox. Castrol Transmax Dex III, Fuchs ATF 4000, Millers ATF DM and Motul Dexron III are good cheaper alternatives.
http://www.opieoils.co.uk/c-1432-atf...ion-fluid.aspx
A 75w-90 is ideal for diff
http://www.opieoils.co.uk/c-673-75w-...ion-fluid.aspx
The Fuchs Syn 5, Millers CRX, Redline 75w-90 GL5, Motul Gear 300 and Gulf Competition are ideal for the diff. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Amsoil FGR are also good choices.
Tim
Tim
Glenn take it to your local axle and gearbox work shop. Guy near me don't mine for 50 quid New seals and bearings. There have to be done correctly or your fuck it up. I believe it's something to pre-load and backlash.
TPM961
15-01-2018 11:50 AM
Adam Graham
06-09-2015 07:04 AM
