L8 048/01 ECU maps check
Can somebody check my ECU maps?
First map is unkown edit, more fuel, some changes.... I bought car with it. After 40 minutes on idle, 0,5l of petrol is in oil.
www.wi-telecom.sk/ecus/L827C128ORG.bin
Second map should be original for L8 048/01, but with this map...engine doesnt start
Is possible, that first edited map..has some HW changes in engine? I dont understand why engine is not running on second map..only one explanation is, that there is something (changed) in engine...that can run only with first edited map. Thanks !
If it is a pectel one the original file wont run.
yes there is a pectel board....but original L8 048/01 ECU has pectel board...or not???
Thanks
www.wi-telecom.sk/ecus/S6300785.JPG
this is it
Thanks
this is it
http://82.234.166.107/site-ford-rs/P...20uk/main8.htm
Thanks! you solved my problem. I have a pectel babyboard in my L8. That is not original.... I need standard L8 eeprom for pectel board. Or remove the pectel baby board and replace by original.
Thanks
Thanks
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
DixieTheKid
14-09-2015 09:04 PM
