T5 gearbox problem??
Old 28-08-2011, 07:51 PM
mpales
mpales's Avatar
Default T5 gearbox problem??
Two days ago when i tryed to down shift from 5th gear to 4th gear....no possible.All gears working properly when start to change from 1st to 2nd...3rd to 4th....to 5th.If i reduce speed i can only change gear from 5th to 4th when my speed is not over 30 klms
What happend,i dont know...any advise welcome...is it sunchro???something else?
This problem happen only from fifth to 4th gear...
Old 30-08-2011, 07:31 PM
opposite lock
opposite lock's Avatar
I cant give you an answer but can give you link to somebody that can
http://www.gearboxman.co.uk/
Old 30-08-2011, 07:50 PM
2ndGear
2ndGear's Avatar
its a syncro problem (very common) the hub shifting plates explode - fit stronger billet ones
www.gears.tv
Old 30-08-2011, 07:56 PM
LHD220Turbo
LHD220Turbo's Avatar
sounds more like a baulk ring issue, i had the same issue on my t5
Old 30-08-2011, 08:15 PM
martysmartie
martysmartie's Avatar
I am pretty sure this is the correct answer as well.
Martin
Old 31-08-2011, 09:04 AM
mpales
mpales's Avatar
Thanks for your help...When you say baulk ring issue,is it easy to found this spare part to dealer shop???
TPM961
15-01-2018 10:50 AM
Flateric_2002
15-09-2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
11-09-2015 08:40 PM
fordfiestamk3
11-09-2015 12:52 PM
gingeRS
04-09-2015 06:29 PM
Quick Reply: T5 gearbox problem??
