Swedish Plenum is this worth it ??
Old 04-05-2011, 10:53 PM
martin24uk
martin24uk's Avatar
Default Swedish Plenum is this worth it ??
just found this on ebay and wonderd if it would be worth buying one if it
would make that much of a performance difference ?
http://cgi.ebay.co.uk/COSWORTH-alli-...item41591f31b8
thanks
Old 04-05-2011, 10:55 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
What spec is your engine?
What plenum do you have currently?
Paul_RS
Paul_RS's Avatar
A lot of mappers have moved away from them? Something to do with number 4 piston melting? Not sure how accurate this is?
Old 04-05-2011, 10:57 PM
Chip
Chip's Avatar
By the way, I assume you have seen the bit about it being damaged and requiring welding?
Old 04-05-2011, 11:00 PM
martin24uk
martin24uk's Avatar
Yeah have seen that bit not a problem, and its a stage 3 running
a 4x4 plenum at the moment ...
Old 04-05-2011, 11:01 PM
martin24uk
martin24uk's Avatar
thats no good
Old 04-05-2011, 11:26 PM
Chip
Chip's Avatar
Utterly no pont then, you'll have the expense of a remap for the new plenum and the only noticeable difference afterwards will be it doesnt drive as nicely, and that its the same amount of power with slightly less boost.
You might gain like 5bhp or so if you are lucky, but that will be the limit of it realistically.
Old 04-05-2011, 11:51 PM
botters
competant bodger
botters's Avatar
they blow welds for fun and dont have equal airflow to all 4 cylinders (much like a standard plenum lol) if you want to upgrade get a small turbo escort plenum or a hart plenum if you really want to go for it, allthough if your not planning on 500+ bhp then stick with the 4x4 plenum you have and spend your money on something else
Chip
Chip's Avatar
Agreed on the escort plenum being the ultimate for upto about 500bhp
Old 05-05-2011, 05:16 AM
martin24uk
martin24uk's Avatar
No problem, Thanks for the advice people
Old 06-05-2011, 05:02 PM
martin24uk
martin24uk's Avatar
what about my 4x4 manifold with a plenum spacer, would that make any difference ?
i know i am a pest !!!
Old 07-05-2011, 09:10 AM
rsmark86
rsmark86's Avatar
the swedish inlets work but only the r&b swedish or the mk swedish, the r&b ones are tried and tested by scs, theres a guy on here with scs built escos with 680bhp on a swedish inlet.... and i remember m k saying he was supplying a few tuners now
its the cheap shit on ebay and the diy'ers on here that get all the problems and people forget that the car needs a custom remap to suit
but at your power its not worth it mate..... needs to be high 400s + to even think about an inlet change
Old 07-05-2011, 10:57 AM
Chip
Chip's Avatar
Rsmark, ALL large plenums effect throttle response, no matter who makes them.
Martin, I wouldn't bother tbh on your spec, the plenum on your car simply doesn't really need adressing.
Old 07-05-2011, 01:45 PM
rsmark86
rsmark86's Avatar
i know mate but i was just stating that not all swedish inlets are shit, its all about design, people say they kill engines and i was just saying yes the shit ones do, but the well known ones are ok....
although the hart inlet is the way to go.....
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
gcfcos
59
06-10-2015 05:04 PM
Oranoco
12
02-10-2015 02:18 PM
Iain Mac
30-09-2015 09:39 PM
Nick 172 Sport
28-09-2015 07:21 PM
Quick Reply: Swedish Plenum is this worth it ??
