Sierra steering rack
Hi guys
Will a standard non power sierra rack fit in a sierra cosworth as I am going electric power steering and will maybe use the sierra rack with the quaiffe quick rack and pinion conversion?
Cheers Dave
Cheers Dave
steering
I run it on my 3 door rally car, one of the best things I have ever done!!
I use a std rack with the quaife kit in.
Hi, you will need the non powered steering coupling as its longer than a std one. If you can replace the lower "rubber" jiont with a poly one or another u/j.
I have seen racks and quick kits available, but not found the steering joint coupling anywhere
chowfornow
14
05-01-2019 09:01 PM
Adam Graham
06-09-2015 06:04 AM
