Cos Misfire.... Burning out rotor arms?
Cornish Fasty
still chasing the mis on my car, and i've noticed that my rotor arm has started burning out. i replaced it about 2-3k miles ago, as the last one was fucked, just surprised this one has gone the same way so quickly.
any ideas whats causing it? want to keep her running as smooth as i can till i get the rest of the bits i need for wasted spark.
i'm running a grp a coil, magnecor leads and 071, gapped to .7-.8 (can't remember which
cheers
cheers
having same problem as you!! burnt rotor arm and cap,mine is causing a miss high up the range. as you i have group a coil and 071's although i gapped mine to 0.6.you havent tried replacing the cap at the same time as the arm have you?
.7 to .8 is very wide, especially if running higher boosts.
There only needs to be a gap so the lecky can jump, big gaps do nothing power wise, the reason big gaps are associated with coilpack is simply when lean burn tech came out a stronger spark was needed to ignite the harder to ignite weaker mixtures, this was achieved with bigger gaps/better coils.
Try dropping to 0.5mm gap, any resistance to the spark occuring such as a big gap and higher boost will put strain on other parts, as lecky is lazy it will seek the easiest way out, this can be through the rotor arm(arcing) and other things.
Using precious metal plugs like IK27 etc helps massively in this respect, as they fire so much easier.
Cornish Fasty
I'll have a go tomorrow, tabs. i dropped them to 0.7 tonight, and it seemed to help a little. sometimes it decides to run fine, though, so will see tomorrow
davy, new cap with the arm.
my brother had a dutton kit car once and his was blowing rotor arms alot,took it to a garage and they said the timing was out abit and the wire terminals to the dizzy was full of dirt and oil,he sorted these problems out for him and car ran like a dream,
OrionRST200bhp
29-09-2015 08:30 PM
