engine specs
#84
I remember everything being black in the bay so just got the wrong paint colour ! doh
Edit found the thread !
and pics
https://passionford.com/forum/genera...ling-road.html
and pics
#88
Standard head and cams although from speaking to Harvey those builds usually had one of his inlet cams in it. I don't recall anything being written on it when I did the head gasket on it for the new owner though.
Changing the cwp made a massive difference though, more power would of been nice but with reliabilty like it had he just left it as it was.
I guess you reconize the car from "that" video
#92
It was mapped by Ahmed I believe back in the day, L8 with pectel board etc..
Its now on Siemens, closed loop and a msd chip which in fairness has made it 200% better on fuel and far less likely to fry itself now it has one of Ryans looms on it.
#94
So going back to power on T34s, i've never believed they'd make a true 400bhp, but after seeing this graph on a .48 i'm guessing with the correct Spec on a .63 housing 400 is possible?? but for turbo length of life i'm guessing not long.....
#96
B1mbo
But then turbo life as you say isn't great over 400bhp as your having to hold a fair bit of boost in at the top
#97
Very interesting that Jimbo..
Mine's going to have some more work done on it next year, just haven't decided on what Turbo yet, or stick with the TT T35.63 i have as it's brand new, and get the 4x4 Inlet fitted and an Inlet cam too then fresh map....
#99
The point your missing is that dyno plot is wrong!!
In 4th gear and proper inlet temps that car would be 350 hp and around 370lb ft
As jimbo has said 400+ is possible but doesnt make for a nice road engine as the cams are too lairy..
The best t34 road spec is as mentioned and will do circa 380 hp in car!!
cheers danny
cheers danny
I always believed it was on a .55 housing but turns out once we had the turbo off that it wasn't.
It did run a LOT of boost though but then as I said never once went wrong in all the time I've ever known the car, engine was immaculate inside when we had the head off as well.
#100
Good to hear that too mate, it does get my back up when people harp on about Cossies being unreliable etc etc, a well mapped/serviced/built Cossie will last for-ever if you look after it..
#102
1 Post
Christ this thread's still going
Anything around or over 380bhp on mine when done I'll be well happy, and probably shitting myself regardless due to the harsh ride.....anyone have some softer springs??
#103
As you say good engines if their looked after
#108
No, long studded 200 block, Dave did about 5 trackdays and the ring with it weeping slightly and it never got any worse so didn't really want to pull a perfect working engine apart.
He sold the car reasonably cheap so the new owner spent a few grand on it replacing some of the worn out bits.
Its a tidy car now and probably won't ever be seen on track again as the new owner is a bufty lol
I'm keeping my fingers crossed I get similar reliabilty from the new one lol
#110
hi was having a read and was wondering if any one could tell me how i could get 330bhp-350bhp out of my 2wd saff ive never had it on the rollers so dont know what its making it the min
fitted on the car is
t3 turbo
yellows
group a k&n
group a o44
group a coil and motorsport leads
rs 500 pace intercooler
3inch stainless exhaust
stage 1 chip
3 bar map sensor
and a new fuel pump loom
any help would be great
t3 turbo
yellows
group a k&n
group a o44
stage 1 chip
3 bar map sensor
#112
Well your T3 will be on it's last legs @ around 320bhp
So for your desired 350 i'd opt for..
T34.48
Actuator
Greys/55lb Injectirs
Live map (imo)
Ans away you go with the rest of your Spec, it'll be a HOOT of a road car then, no lag like your T3 but pull harder..
T34.48
Actuator
Live map (imo)
#113
cheeRS forgot to say -31 actuator and a set of turbosport cam pulleys and 4x4 inlet
see i live i northern ireland and i dont know of any cossie tuners over here ?
so thats why i ask as i was told if i was to go up to 330-350 in need a stage 3 chip and a few other bits
JoeyBoyden
04-01-2024 02:36 PM
09-10-2015 07:38 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
