this turbo any good
As said it's a T4 so will be very laggy, woulden't be my choice personally, I think that name applies to all the turbos I.E T03 is a T3.
You need to look at your current spec, decide what you want from the car a choose a turbo accordingly (More than likely a T4 is overkill)
The car among other factors most importantly needs to be mapped for it.
Martin
Martin
to4e are ok cheap turbos!
the only thing i hate about them is the 5 bolt housing on the turbine side, theyre similar to a t4 yea, but dont live long at high boost.But for th money theyre good
Youl need a manifold with an external wastegate for that tho mate, i also have a brand new gasket and flange for the turbine housing il sell you if you like, i was going to use one of those turbos on a civic i had
You don't need a manifold with wastegate, you can get a integral wastegate part that fits on the flange on the turbine as I run this on my T3-34, and know they are available for the T04.
escort rst cosworth rep
ie;' the mistake i made cheap parts get you no were
is there any play on the turbo and it should work what type of psi you want top run
Thats a cheap t34 copy not a t4 and they work fine on jap crap running around 28 psi but go over that and they fall apart...
Go gt3071 internal gate 83lb siemens,nice inlet cam and you will have abeast mate and a lot cheaper than youd think!!!!
cheers danny
cheers danny
Matt Baxter
16-09-2015 08:30 PM
