Does anyone runs 8" wide wheels with ET32 at the front on their saff 2wd? If yes, does it fit inside the arch without any mods?
The reason why i'm asking because i just received my wheels that are ET32,5 at the front and i'm not sure whether they will fit inside once the car is lowered to the ground.
Cheers mate. Just what i was thinking, with a offset lower than 33 the arches needs to be rolled. Definitely not going to do that on mine so i will have to send the wheels in return
Just roll the arches, Saffs look so much better on a et32-35 with 8" rims
Plus it very much depends on the height the car is running at.
I know mate but i originally ordered et35 and got et32,5. Still going for 8" but hopefully et35, better to use a 1 or 2mm spacer to adapt them perfectly without the need of rolling arches.
