torque settings on 6 long stud block?
as above what is the torque settings on a 6 long stud block an also do you have to get new nuts?
many thanks
many thanks
ok cheers pal,i had to have a 18mm socket shaved so i could take the head off,hopefully it wont snap or crack....is there a special tool or anything to but to remave the nuts?
cheers
cheers
cheers for the help peeps,how about the 4 bolts?are they the same torque settings as the nut an stud kit?and do i get new bolts...many thanks
Use new stretch bolts on the end holes that's what most seem to do, then follow one of the few different ford recommendations for tightening.
I don't use the long studs but just do my(2wd) arp stud and nut kit up to 120 lbft.
James Porter
28-10-2015 12:17 PM
