Missfire On My 3dr
Missfire On My 3dr
Evening all, the other day i posted up regarding a missfire i had on the 3dr, unfortuantely i'm still no closer to sorting it?! It just started to happen the other day out of the blue, the cars been driving great up until then!
The symptoms are, the car appears to drive ok up until the car hits boost, as soon as my boost gauge goes past 0 on the boost gauge i get the missfire!
so far i've changed:
Fuel pump
Fuel filter
Fuel pressure regulator
MAP sensor
Checked plugs (all seem to have good burn and spark)
Disconnected the brown plug (ACT) sensor and it made no difference
I've done a test with WD40 to see if i have any air leaks etc with no difference
I have good power to the fuel pump so am happy with that.
I've ordered a phase sensor, crank sensor and coolant temp sensor.(although not sure what the symptoms of a failed coolant temp sensor are?)
Anyone had this problem before?? Am i on the right tracks? Seems odd as soon as the car comes on boost, it literaly is as soon as the gauge moves above zero! Car seems to drive ok up until then?!
As per usual your helps much appreciated guys!!
Fuel pump
Fuel filter
MAP sensor
Have you tested your fuel pump supply UNDER LOAD ?
They can test perfect with no load(idling) but when under a bit of strain the wiring can be unable to deliver the required amperage needed which will cause massive voltage drop.
Just hook some thin wire into the plugs on the pump before pushing the plugs back on the pump, trail wire through window hook up to digi metre and watch it as you drive, may give a clue.
Was the map sensor brand new or a known good one ?
Anyone live near chester with a known good MAP i could try/borrow for 10min to rule it out completely??
Oh, i get you now. Not long had these, be gutted if they've gone.
Unfortunately there arent many cossie owners round my way to have someone nearby to loan parts off to try them out so its costing me a fortune buying new everything to find it wasnt that after all
New set of plugs bcr 8es ngk and try that or check when itd dark and look under the inlet plenum to see if your plug leads are sparking together,two cheap options to check...
cheers danny
cheers danny
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
