fuel pump wiring
fuel pump wiring
i have rewired my fuel pump and used the old live as the trigger.
i thought the ecu triggered that live to tell the pump to work?
as soon as i turn my ignition on i have constant power to the pump whichout turning the engine over.
i thought the pump was supposed to stop untill the engine is turning over??
The ecu should send an initial 2-3 second burst for priming first thing in the day, and then dependant on other factors may do so again, seems to be it's mostly engine temp related as to whether it does so or not, after the 2-3 secs without engine running it should stop, and remain stopped until engine cranking and/or running conditions are met.
ok cheers mate, i will check mine again as i thought it was running and not stoping when i turned the ignition on but not sure is the car was warm when i checked it.
JK12
33
26-04-2021 12:09 PM
kosienutter
31
22-08-2015 09:55 AM
