Comon reasons the indicator fuse keeps blowing?
For the fuse to pop most likely to be a short, I guess it blows when indicating unless you have a short before the switch which is unlikely, if you can trace it down to which side it is blowing on then it will be a short after the switch to that sides indicators/repeaters.
Martin
Martin
Could be something as simple as water in alight housing/bulb holder.
Excess current is why it pops anyway, ie too much load, resistance test should help track it down quick after taking all 4 indicator bulbs out, and the square wing ones.
They are both on the same circuit, hence no power without ignition, so you won't have reverse lights either with blown fuse and it would not explain why it blows overnight, do you reverse into the garage? If so it might be blowing in reverse but then you do not realize to morning and think it has blown overnight.
Martin
Martin
I had this problem, checked everything and then I gave the wiring loom down by the reverse light switch on the gearbox a tug and made it rest in a different position and its never done it since!
07-10-2015 12:56 PM
Mark_
40
02-10-2015 04:40 PM
SMILER258
28-09-2015 09:04 AM
