Wasted Spark ?
How efficient is wasted spark,does it draw more,or less current than a group "a" coil.Is wasted spark supplied through the ecu,or does it have a separate loom that drives the coilpack.
thanks matt
thanks matt
very efficient mate, apparatly the best mod for a cossy although ive not done it myself yet. You will need a seperate driver board for l6 l8 to be fitted inside the ecu and also a fly loom to drive the extra ignition amp, ive herd jano is the cheapest for the whole kit
iv got a MSD wasted spark on my car . i got it as a DIY kit very nice mod there is one or two down sides with the kit some times when i turn the key i will get a coth from the motor as all the plugs fire at the same time it will never start but it is funny . you will all so have to keep your spark plugs down to a small size on the gap like .65mm not wot you would think like a mondeo which runs over 1.00mm . all so the kit will some times play up with you rev counter and will need a small bit of we wiring to sort it if running a ford clock set up . the one big down side iv had is you have to mod the ECU for the wasted spark and put some new wires inside the ECU plug which mean if you need to test a new ECU on the car it wont work unless you revers the wiring back to standerd which is a pane in the ass . but at the same time when its working it works very well
one of the best thing i did to mine,msd one,they fitted driver into ecu,so was really just plug and play,did need to modify tacho,full instructions and was easy enough to solder the wee loop wire in at the back of the tacho,seemingly not all need tacho modded,never miss fires in damp now,which it always did before unless sprayed wd40 on connections to group a coil and cap etc every other day,cars my daily driver
colin
colin
what the mod on the rev !
With differing compression including adiabatic, this will alter how much spark you can get away with.
If you use a ACCEL coil in place of the early zetec type this gives around 40% more spark power, around Ł36.
Sorry got a little Question.
I have bought me the MSD Wasted Spark Kit, but they forgot the instruction,
Can anybody send me a mail with the instruction?
christianwolf@chello.at
THX Chris from Austria
Steve has been on holiday this week, so that may explain why you got no reply, if the email had directed to him.
i think ive caught up today, so hopefully this has been sorted now. if not let me know and i will fire them over to you.
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
DixieTheKid
Sep 14, 2015 09:04 PM
