steering problem
steering problem
hi,steering on 4x4 seems heavy and sticky,but not all the time,getting worse tho im sure,was heavy at a junction so dont think its tramlining,cant really see fluid moving in steering fluid resivour(sp),is the steering pump failing?another/new pump or anything to check before that?
any help much appreciated thanks again
sure i didnt see fluid moving when idling,car was cold when checked would that make any difference?
will double check then go in search for a pump
The easy way to see if the pump is pumping is simply to remove the return line, and put in a bottle etc temporarily, start engine see if fluid comes out.
It might be worth trying some WYNNS steering system conditioner, as this helps ungum the rollers of the pump.
The viscosity of ATF varies very little with temperature.
I'm sure they are roller pumps on the cossie, but if vane type both can be overhauled really easily.
Other things are blocked valves in the rack on either side, is it easier one way than the other ?
The main problem is the age of the pipes now, as they do deriorate, INSIDE and the bits of lumps that fall off jam up/restrict the one way valves, that shut each time the wheel is turned.
cheers guys,i'll disconnect pipe see if its pumping,replace fluid as its bound to be ancient!will add in wynns stuff as well,
where are the valves on the rack?are they easily checked?
not sure if its worse one way than the other will find out in morning,feels pretty scary anyway,bit of luck i'll get that done tomorrow afternoon
thanks again
thanks again
having a similar problem. myn is really noisy and abit lumpy. Its the rack on mine, i changed my pump to na avail. but urs sounds like it may be the pump or a pipe blockage. as silly as it sounds make sure the pipe isnt the wrong type and has creased. its meant to be very firm pipe, if its a soft one like people often put on they bend and kink abit like a hose pipe.
when car was hot could see fluid bubbling,disconnected pipe(top one on resivouir)started car in no time it had pumped out all fliud,seemed clean but very dark,have renewed fluid but couldnt get additive stuff,will give her a run in a wee while and see what like,thanks again
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
