Chassis rail/beam pad thickness
Old Nov 11, 2009 | 08:41 AM
pacwest's Avatar
pacwest
Puller of the Wrench
Default Chassis rail/beam pad thickness
I've got some bad rot I'm going to weld up behind the beam pad where the isolator goes.
Essentially I want to replace from the bolt hole to the upsweep curve. No biggie, I had planned this. Well I have to since there is no steel around half the pad/bolt hole for the isolator/bushing! My question is though how thick of steel was there stock? Not much left for me to go by!
Better to weld in one plate or two thinner ones? I can see some 12 gauge doubled up and gusseted looking quite habdy.
Old Nov 12, 2009 | 08:07 AM
pacwest's Avatar
pacwest
Originally Posted by pacwest
I can see some 12 gauge doubled up and gusseted looking quite handy.
I think I've answered my own question here but no takers as to an opposing opinion?
12 gauge sheet metal is 2.6568mm thick. Doubling/gussetts it will make 5mm of steel laminate.
Old Nov 12, 2009 | 08:15 AM
I would of said more likely to be 14 gauge, but just repair as best you can, how you want to.
Old Nov 12, 2009 | 04:30 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
sounds fairly good, bud.
Old Nov 12, 2009 | 08:50 PM
opposite lock's Avatar
opposite lock
ouch thts nasty, good luck with sortin it, i had 1 side on mine done by a friend, i was so impressed with the job i paid him a bit more. He saved me a fortune and everything measured up spot on with 5mm sheet if i recall (not sure) full respect to you guys tht tackle this sorta thing.
Old Nov 30, 2009 | 06:12 AM
pacwest's Avatar
pacwest
I ran into my own thread searching for something else and thought I'd add that I welded in 5/16 steel just fine recently. Welded up quite nicely with the double wall that exist from Ford. Laying two sets of beads with the mig then grinding them down resulted in a perfect fix. Flux core works great here.
Hopefully this can help someone else.
Old Nov 30, 2009 | 11:05 AM
opposite lock
nice one pal , any pics?
Old Jan 8, 2012 | 10:11 PM
BON_300's Avatar
BON_300
any pics ?
Old Jan 9, 2012 | 05:57 PM
I know its an old post but it woud be nice to see pics of the repair.
Old Jan 9, 2012 | 06:16 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
lol bit of an old thread! funny anough ive just done mine, i had to double skin it like the original but deffo alot stronger than it was;
before
cut out
first skin
outter skin
ground down
Old Apr 4, 2016 | 05:42 PM
choppen's Avatar
choppen
is there not no repair panels to buy to repair this?
Old Apr 4, 2016 | 06:31 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I did mine with 2mm think sheet. I'm not show and shine just wanted it fixed and you can't see it under the beam.
Old Apr 5, 2016 | 04:40 PM
Ridgey's Avatar
Ridgey
Yes, you can find chassis leg sections, I've just had mine done using the middle section of a new chassis leg.
Old Jan 19, 2019 | 09:32 PM
nathcos's Avatar
nathcos
When removing the rot where the beam sits how do you go about measurements for the beam as mines rotten.
Old Feb 26, 2019 | 08:04 PM
The Youth.'s Avatar
The Youth.
usually you can leave the round section with the thread in,in place so the beam mount point doesn't move.
Steve
Old Mar 15, 2020 | 09:18 AM
Cox89's Avatar
Cox89
2000e
Hi. I have done a similar fix,
when cutting out the fitting, cut a square around it that you are going to replace if possible and use it as a rough template so that you can drill a hole in the new metal in similar spot , for the thread fitting to fit through,
Sand off all spot welded metal on fitting so your left with the disc,
when you have your new piece ready to fit to chassis leg , drill 6 holes around the hole you cut out for fitting to spot weld,,
Now put the fitting into the repair piece dont weld in yet just let it sit in the hole
tack in your new metal, 4 tacks will be enough to hold,
Get your bracket that fits onto the body of the car and also holds the rear beam in place put in the two bolts that secure it to the car,
get a piece of pipe or use the centre pipe from your beam mount poly bush and screw the long bolt up through the pipe and screw it into the threaded fitting, this will give you the position in which the threaded fitting can be tacked using the 6 holes to spot weld into position,
Best of luck
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
