Sparkplug gap 071c
Old 01-10-2009 | 06:22 PM
RSRoy's Avatar
RSRoy
Default Sparkplug gap 071c
Hi guys,
we have been building my brothers Sierra 4x4 engine from scratch. It's build up with 100% original Ford or improved parts from Mike Rainbird and will be pushing 270 bhp max (may be a bit lower).
The plugs we use are Motorcrafts 071c's but we are wondering at wich gap we need to set them? We've been told around 0.9 mm.
FYI we use new motorsport leads + new dizzycap, rotorarm, fuel pump etc
Regards
Old 01-10-2009 | 06:59 PM
jon@work's Avatar
jon@work
a typically used gap for these plugs that seems to work for most people is 0.6-0.65mm
Old 01-10-2009 | 08:02 PM
RSRoy's Avatar
RSRoy
That is OK for all specs of engines? Think most people use these gaps with higher specs. Can anyone confirm?
Old 01-10-2009 | 08:12 PM
I would use as jon says, 0.6mm, the std coil on the sapphys is not particularly good, unless you have fitted the excellent "group a" coil ?
Old 01-10-2009 | 09:08 PM
RSRoy's Avatar
RSRoy
Standard coil is fitted atm. Then we go for 0.6mm as you guys say. Thanks for the help
Old 02-10-2009 | 06:36 AM
grcossie's Avatar
grcossie
I use this plugs, and a Mallory higfire 6al, grpA coil, and 10mm plug cables. I run whit 1.0mm gap on 1.8bar pressure whitout problem. Much better idle, and burn better all the way
Old 02-10-2009 | 08:27 AM
They can be opened up when using a group a coil, and I also found it very beneficial in smoothness and idle quality, I ran 0.9mm.
Old 02-10-2009 | 08:36 AM
KSA-Cossie's Avatar
KSA-Cossie
Or go wasted spark and run bigger gaps abd getba better idle imo.
Old 02-10-2009 | 10:55 AM
grcossie's Avatar
grcossie
This is cheaper than wasted spark, and works well
http://www.malloryperformance.com/Pr...minselection=1
Old 02-10-2009 | 02:28 PM
If going coilpack for a better idle, may as well go the whole hog and get a better ecu that has idle smoothing with ignition.
01-11-2015 07:53 PM
Chas
05-10-2015 08:13 PM
pabloXR
21-09-2015 01:42 PM
Bailes1992
19-09-2015 03:17 PM
wheelwizardrefurbs
18-09-2015 09:59 PM
