3dr cosworth engine won't start.
just tried getting the cossie to start but it won't, it turns over but won't fire. the engine management light stays on.
its not been started since last august i've been tidying the engine bay up and it has been steam cleaned back in august.
any ideas where i should start? fuel pump is priming.
cheers Matthew
cheers Matthew
I'd be looking at the MAP sensor. Is the loom still pluged on ok,has any moisture got into the plug and is the earth strap still attatched under the screw that holds the MAP sensor?header tank in place. If all thats ok then i,d check all the other sensor connections for moisture especially the crank position sensor . Its also worth having a look inside the dizzy cap for moisture and check the plastic covering the wires inside the the dizzy on the phase sensor. The plastic tends to go brittle ,fall off and allow the two wires to touch each other .
If you have spark and fuel, check crank and phase sensors. Mates 3 door did the same, it broke the phase sensor while parked up
CRANK is 0.6mm to 0.8mm, PHASE is 0.3mm to 0.4mm.
The crank sensor will work quite a bit outside these limits, phase is easy, but fiddly, just a screw/s holding it to the plate in the dizzy after removing cap and arm, then sheild(if fitted).
Check lead order on dizzy cap.
big_Rad
15-09-2017 09:36 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
