4x4 fuel pressure regulator
Passion for Fords!
by all means adjust it.....if it needs it.
ie you need to measure it ,and set the line pressure to 3.5 bar at idle with the vac pipe off and blocked.
she will need a fueling and det check after any adjustments are made.
you will be amazed how many monkeys out there tune cossies via the fuel reg
my advice would be get her to stu asap, and let him run some diagnostics on her to make sure your sensors are ok, then he can set her up! and you can drive home with a smile
Passion for Fords!
the global mod is a trim screw for the whole fuel table,
as you adjust it it adds or subracts a percentage from your fuel table,
this is why the fuelling needs checking on full boost after adjustment, as when you wind the idle co down, you also reduce fuelling at the top
Wahoo! that worked, thanks for the advice guys,
James, the global mod screw is the one that did it, that and the fact we had an air leak on the inlet manifold.
Running like a dream now, got the boost down to 6 psi to keep it safe, will potter up to blackpool on friday now!
What is meant is to spray easy start(containing ether) around joints gaskets etc, then any leaks it gets sucked in and causes the revs to change, so you know if you have a leak.
The added bonus of using easy start is it cleans your engine as well, so isn't such a waste.
JK12
33
26-04-2021 12:09 PM
