Fuel filter, fuel pump & wiring question
i'm going to replace the fuel filter on my Sapphire 2wd as it looks pretty old
fuel pump & wiring looks to be original too (70k ish)....... should i replace them too?
as i'm looking to use the car on trackdays, is it a good idea to fit an uprated pump (may put it up to stage 1 once i'm used to the car)
3 door resto in progress
its defo worth getting a fuel pump rewire loom as well
as this is a common fault on these cars
the wiring corrodes and creates a high resistance
this drops te voltage at the pump
so defo worth doing a rewire, for safety and reliability
I'm not good at wiring so I bought one of the Prometheus ones off The Ebay. It looks very well made and if you're not good at wiring I'd recommend one. There's also a few people off here that can make one for for a fee.
Better than your engine running out of fuel on boost
Std 941 pump is plenty ok till at least 380-400 bhp, but rewire is a must as is fan rewire.
If you're ok with wire etc less than a fiver each bit pump/loom.
It's not the wiring I am bothered about it's getting the proper bits like the mushroom connectors etc.
Want to keep it original Ford looking.....
any comments anyone I was going to buy one off Ebay as well but £45 is a bit expensive.
The loom I got from Prometheus assumes you have an 044 but you can ask him to do the fittings for a std pump so I've heard
kosienutter
31
22-08-2015 09:55 AM
ekjim
17-08-2015 08:57 PM
CabrioTurbo
01-08-2015 11:04 AM
