Sapphire Cosworth 2wd cutting out/stuttering
Hi,
My car is cutting out or stuttering when accelerating. It always happens when accelerating, at half throttle or harder. I cant ‘make’ it do it, most times I can plant the throttle and it’ll just pull through to the next gear change fine. It just randomly happens, it usually catches me unaware, but it is like a boost cut.
Pretty sure a boost cut would come in every time I accelerated up through the gears? And not at half throttle?
Has happened quite a few (random) times now, at first I thought it was due to low fuel level. Started doing it about two weeks ago.
Once the stutter has passed, about 1 or 2 seconds, it carries on accelerating as normal…
The car is pretty much standard.
Could it be the fuel pump?
How olds the fuel filter ?, though this would tend to not clear up after a few secs when still on boost.
I would do the wiggle test, particularly the CPS connector.
It's possible to be the pump but does not sound like it, but I assume it is rewired, the same as the fan circuit ?
Mine did about the same, turned out the actuator was broken. It's most likely to occur at low revs and partial throttle, 'cause that's when the pressure will be the highest (provided the actuator does nothing). Now my fuelpressureregulator is broken, leaking into vacuumhose, so I have a lot of rubbers failing on me lately :-(
it could be lots of things to be honest
if you cant take it to someone who know's what they are doing, then start with the cheap things
1) old fuel filter
2) old fuel
3) Phase sensor
4) crank position sensor (CPS)
my money is on the CPS or phase sensor
1) old fuel filter
2) old fuel
3) Phase sensor
thanks for the help guys!
have done the 'wiggle' test, it hasn't cut out since yesterday.
But the randomness of the cutting out/stutter means i don't know if it's sorted yet.... time will tell.
Started reading about the phase sensor, i think there maybe more reason to look to this than anything else. If anyone has read my other posts, my car is smoking a bit under load, possibly bore wash from overfuelling (hopefully that and not rings!) which, if i've understood it right, can be caused by a dying phase sensor....
Could i be on to something here?
Might try this, not too pricey for once!
normally if its fuel it will be a balck'ish colour
if its blue colour it be be anything from, rings, stem seals, guides or turbo
i would always recommend renewing all sensors; MSD so a sensor kit for around Ł80 (i think) but not sure if that includes phase
replace the cheap things first then go from there
it's bluey grey smoke, the fuel washes the oil off the bores, causing the smoke and oil consumption... (i think i'm right there?!)
the head and turbo have been rebuilt about 2/3000 miles ago, so can almost rule them out.
hopefully it's all down to fueling and not rings just yet! should get some answers on thursday on the rollers...
sensors are on the 'to be done' list now anyway, whatever the result...
cheers for the help
cheers for the help
Hi rich.edrsoc, did you manage to figure out your turbo cutting out? I have the same issue, on hard acceleration, my turbo does not engage, almost like ECU cuts off the fuel. I pump the accelerator multiple times, and then it randomly kicks in?????? It does this rather more fequently.
I'd check the dates on these posts your replying to or start your own to get direct replies.
Yes, some of the posts are old, but they may still be around and may have sorted their cutting out issue, and might be willing to share??? If you don't ask, you will never know, will you?
True, but from experience starting a new post specific to your problem will get a better pool of answers.
Good luck in sorting your issue's.
I have been advised to check the "Cam Timing Sensor" to make sure it is parallel to the trigger and is gapped properly between .20 mm to .30 mm. It feels like it is the ignition cutting out. So, if the dizzy shaft is worn, and have a greater than 4 degree of play, it needs to be rebuilt, as it will not stay gapped properly under load. There is a website in the UK which is very helpful for YB engines. www.autodynamix.co.uk They have a step by step instruction how to perform the check, as well as a wealth of other helpful tutorials.
accelerating, cosworth, cuts, ford, low, oldsmobile, phase, revs, rs2000, sappihire, sensor, sierra, smoke, stutter, stuttering
