incar bleed valve
11-01-2009, 09:00 PM
incar bleed valve
are they any good if so wots the best way to fit it
12-01-2009, 04:27 PM
Get the boost set up buddy and will be no need for a bleed valve
messing with a bleed valve normally ends in tears.
12-01-2009, 05:19 PM
wots the best way to do that and who would be best people to set it up properly in yorkshire area cheers
12-01-2009, 05:36 PM
Passion for Fords!
in car bleed valves are shite, the length of hose required to fit them and the valve itself can cause wastegate creep.
just adjust the arm as normal.
12-01-2009, 05:40 PM
get a proper one under the bonnet. and get the car set up and leave it....
12-01-2009, 05:46 PM
BMW RS DIESELWORTH
Quote:
Originally Posted by
bigad4x4
agreed you will end up next to a scoob/bike or something at the lights turn the boost up full wack and end up melting the engine !!
12-01-2009, 05:54 PM
andyroo2
Well Lane Turbo Centre are in Batley but it's worth travelling a bit further to Motorsport Developments in Blackpool.
13-01-2009, 05:38 PM
paul thornton
I have seen it first hand paul some chap in a FRST the only tears being mine with laughter
01-11-2015 06:53 PM
Chas
05-10-2015 07:13 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
markk
09-09-2015 08:11 AM
