hello,
I'm writing from italy, i'm preparing a sierra cosworth for drag race and i saw in internet that the 10.5" jaguar diff is a good solution with an adjustable rear beam.
Can please somenone indicate me where i can find one of these complete with driveshafts diff and beam??
is it just the standard beam with the mods to make it 6degree type ?
or are the diff mount points different for the jag diff ?
Everything was different, ie adjustable rose jointed arms etc along with new diff mounting points. Also you'd need modded/new drive shafts and prop shaft to mate up to the jag diff. iirc Rod also ran a zoo jag diff conversion??
Still run the Zoo beam/Jag Diff conversion have found a source to make spare drive shafts because Zoo no longer trade. My prop had to go from Jag Diff to TKO box & it is huge with enormous joints hopefully will never break.
Try Danny at Adrenaline.
Which beam do you want the one with the jag diff in? I have a spare jag diff if you want one as well ... Drop me a PM with your mobile number please mate
As a matter of interest which jag car does the diff come out of and has it got a lsd .
i have a zoo rear beam ,and i will be needing a diff and drive shafts and was wondering is it much more expensive to go down the jag route over the standard rs set up
cheers james
cheers james
Mine came from a Daimler Limo its has 2 tags one gives ratio 2.54 & the other says Power Loc. I paid Ł20 ( actually some Tesco wine in exchange).
Sent it away for overall & shotpeened that cost Ł440 , it was fitted in around 2002 & aint broken, have broked 2 sets of driveshafts.
Are you sure it's 2.54 not 3.54 Rod? Might be a typo as that sounds a hugely long Ratio? . Mine is 3.54 LSD powerlock, believe most older jags had them?..
The drive shafts are made as far as I am aware from the front half of a cossie propshaft, one end UJ one end CV joint ... Seriously beefy units
Think we've just discovered Rods top speed secret?
RUBY123: Yeah find out matey and let me know....I had his mobile number but it was about 6-7yr ago so doubt it would be same now even if I still had it stored
I did a engine rebuild on a 60's Daimler Limo a fw years back and was eyeing up the diff then....nice chunky unit. tbh I think most people on here could just buy and fit if in good condition and not bother with shot peening at all.
