Part numbers - added more parts,
Me Cossie Runs Atlast!!!!
Right, seing as ive had alot of bits from Ford for my saph build, i thought i would start a list of the finis codes. Might help others out. If anyone else wants to add theirs to it that would be great
6068981 Bonnet stay hinge grommet,
6163722 Nut Exhaust manifold to head,
1436267 Nut Inlet manifold to head
1604703 Power steering pump banjo washer
6514373 Clutch Cable
6119483 Nut, Expansion (the one in the front bumper for the number plate)
6175872 Clip - Throttle cable - Body and pedal end.
6096256 Bumper - Bonnet (The Rectangle block on the wing)
amal valve pipe clips-1666823-7-
front sideskirt clips-1659676
rear sideskirt clips-1659678
fuel pump rubber bobbins-6167524,beware,they cost £29.50 inc for 3 bits of rubber.
HEAD GASKET SET (standard) 5017402
THROTTLE BODY TO INLET MANIFOLD GASKET 1635718
ROCKER COVER GASKET 6542373
OIL PRESURE SWITCH 1066811
AIRCON DRIVE BELT 6460879
SPARK PLUGS (PLATINIUM) 6762458
CAMSHAFT OIL SEALS 6542378
CAM BELT 1639171
WATER TEMP SENSOR (GAUGE) 6145143
ALTERNATOR AND WATERPUMP DRIVE BELT (MULTY "V") 7064725
ROTOR ARM 1641611
DISTRIBUTOR CAP 6542391
CLUTCH & PRESSURE PLATE & BEARING 5029625
FRONT PROP SHAFT XFERBOX OUTPUT SEAL 1645381
FRONT DIFF TO SUMP SEALS 6144621
FRONT L/H DRIVESHAFT INNER CUP TO DIFF OIL SEAL 1096669
FRONT DIFF R/H SHAFT CUP OIL SEAL 1096669
FRONT DIFF INTERNAL O-RING FOR L/H SHAFT 6144623
FRONT R/H LOWER TRACK ARM 5021462
17' WHEELS RS 7 spoke 5051932
STEERING SHAFT PLASTIC BEARING 6121994
STEERING SHAFT GROMMET SEAL 7042536
STEERING SHAFT BUSHING 1638549
STEERING RACK TO COLUMN SHORT SHAFT 6653228
FUEL PUMP RUBBER MOUNTS 6167524
TANK TO PUMP FUEL HOSE 6096322
SIDE SKIRT CLIP INSTALLATION RIVETS 6869991
SIDE SKIRT CLIPS (SHORT) 1659677
SIDE SKIRT CLIPS (MEDIUM) 1659678
SIDE SKIRT CLIPS (LONG) 1659676
BULKHEAD BREAK PIPE SUPPORT CLAMPS 6156157
EXHAUST MANIFOLD TO HEAD STUDS 6184363
CAMSHAFT FRONT BALL BEARINGS 6542370
CLUTCH CABLE 6514373
GATOR FOR CLUTCH ARM 6180410
SPRING RETAINER FOR GATOR FOR CLUTCH ARM 6180412
TRACK ROD ENDS 5021413
FRONT WHEEL BEARINGS (SAPPHIRE COSWORTH 4X4) 5013161
FRONT WHEEL BEARINGS (ESCORT COSWORTH 4X4) 5012478
GROMMET UNDER GEARSTICK 6264135
LEATHER GEARSTICK GATOR 6576236
FRONT CRANK OIL SEAL 1669254
REAR CRANK OIL SEAL 1032209
FRONT CRANK COVER & AUX SHAFT COVER GASKET 1516956
AUX SHAFT OIL SEAL 1669254
FRONT SUMP OIL SEAL 1511264
REAR SUMP OIL SEAL 1639247
OIL PLENUM TO OIL COOLER SEAL 1023905
OIL PLENUM INTERNAL BOLT SEAL 1023910
OIL COOLER TO BLOCK SEAL 6190947
RADIATOR 6627011
RADIATOR FAN SWITCH GASKET 6005731
RADIATOR FAN SWITCH 7001614
RADIATOR SUPPORT RUBBERS 6103130
OIL FILTER 1555451
EXHAUST MANIFOLD WASHERS 1465430
EXHAUST MANIFOLD NUTS 6163722
INLET MANIFOLD ELBOW FITTINGS 1649053
WATER PUMP GASKET 6838365
THERMOSTAT 1668305
TURBO OIL FEED PIPE 1663030
UNDERBODY BRAKE/FUEL SUPPORT CLAMPS 6110209
SCREWS FOR UNDERBODY BRAKE/FUEL SUPPORT CLAMPS 1467843
PWR STR PUMP LOWER SUPPLY PIPE UNION SEALS 1604703
FRONT PROP SHAFT TO FRONT DIFF FLANGE BOLTS 1650759
POWER STEERING HOSE CRUSHABLE HOSE CLAMP 1640474
RADIATOR AND FAN SECURING SCREWS 6554729
REAR ENGINE BAY TO BONNET SEAL STRIP 6703927
WINDSCREEN WIPER GRILL SCREWS 4038458
WINDSCREEN WIPER GRILL LOWER WEATHER SEAL 6479213
PASSENGER WINDOW SURROUND SEAL 1651243
PASSENGER WINDOW SURROUND SEAL 1666979
PASSENGER WINDOW SURROUND SEAL 1666980
R/H REAR PASSENGER WINDOW SURROUND SEAL 1651241
FRONT BUMPER LOWER RUBBER STRIP 6151257
HEADLIGHT WIPER R/H 6151230
HEADLIGHT WIPER L/H 6150229
FUEL PUMP PIPES COPPER WASHERS 6054981
FUEL PUMP 6150295
REAR NUMBER PLATE LIGHT UNIT 6067427
REAR UNIVERSAL FORD MUD FLAPS 1052581
FRONT BUMPER SIDE SUPPORT REPAIR KIT 1129131
L/H FRONT INDICATOR CLEAR LENS 6177865
R/H FRONT INDICATOR CLEAR LENS 6177824
CV BOOT KIT OUTER FRONT 4X4 6672257
Thats a few, will add more tomorrow hopefully
CAM BELT 1639171
ROTOR ARM 1641611
RADIATOR 6627011
OIL FILTER 1555451
THERMOSTAT 1668305
FUEL PUMP 6150295
Always handy mate... most Ford parts departments' need all the help they can get!!!
I've got a few i'll post up when I get the chance...
...come to think of it Mods, can't a dedicated sticky or database be started with these? With so many people doing rebuilds and restos it must be something worthwhile...
Never gonna give you up!
Tim
ye mate covers everything just a pain in the arse to use
heres a few bits i used for my 4x4 sapph rebuild, hope ther some use to somebody
CAM BELT 1639171
ROTOR ARM 1641611
RADIATOR 6627011
OIL FILTER 1555451
THERMOSTAT 1668305
FUEL PUMP 6150295
CAM BELT 1639171
ROTOR ARM 1641611
RADIATOR 6627011
OIL FILTER 1555451
THERMOSTAT 1668305
FUEL PUMP 6150295
Hi all heres a parts list my mate has done with my help all parts listed are still in stock with ford we have only listed parts that are still held by ford... There may be more but we been busy doing other things Hope this helps heres the link...http://www.rsownersclub.co.uk/rsocbb...d.php?t=252967
I bought micro cat of ebay for a few quid...
I need to know the part number and description for;
0800579
1639307
1639311
1641114
6131945
beware,ford now charge £23 each yes each for these crappy things that break all the time.cavalier mk3 fuel pump bobbins fit and cost 78 pence from most motor factors.
ford had a huge price rise this year,£60 on top of £109 for a rear abs sensor which are no longer available!
155lee
06-09-2016 11:10 AM
Fudgey
17-09-2015 01:06 PM
