Bleeding the brakes on saff?UPDATE!!bleed nipple is completley rounded off HELP!!??
Old 18-04-2008, 06:19 PM
rugged rick
rugged rick's Avatar
Angry Bleeding the brakes on saff?UPDATE!!bleed nipple is completley rounded off HELP!!??
hello guys and girls,
wondering if any of you have any idea how to remove a shagged bleed nipple as mine has rounded off and i cant get the thing out for love nor money,,,
P.S it was already fucked before i touched it
any suggestions welcome otherwise it looks like ill be purchasing a new caliper!!!
thanks,rick
Old 18-04-2008, 06:41 PM
SillyFezzaMk1
Rubber Rhino Crew
SillyFezzaMk1's Avatar
mole grips
Old 18-04-2008, 06:53 PM
BigErn
BigErn's Avatar
mole grips and heat
Old 18-04-2008, 07:07 PM
andy888
andy888's Avatar
wouldnt put too much heat near a caliper full of brake fluid! bit of WD, leave for 10 mins then some vice grips as said above. mite shear all the same sounds as if its tight.
could also try and tighten it slightly first then loosen it
Old 18-04-2008, 07:14 PM
cossiegreg1
cossiegreg1's Avatar
Originally Posted by BigErn
mole grips and heat
what he said
Old 18-04-2008, 07:35 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
What he said
Old 18-04-2008, 07:43 PM
rugged rick
Unhappy
tried mole grips and theyre just eating into the metal and mashing it up!!!
Old 18-04-2008, 07:56 PM
cossie_pol
cossie_pol's Avatar
I had the same problem with one on a 106, rounded off and mole grips just mashed it up more ended up buying an Irwin rounded bolt removal set.
iirc was about Ł20 for the set but did the trick!
Dave
Old 19-04-2008, 09:41 AM
COLEYST200
COLEYST200's Avatar
The next thing i would do now is put the bleed nipple in a vice and rock the caliper back and forth its going to do one of 2 fings it will come out or it will brake but your at that stage were theres no going back . if it brakses you will have to drillit out and thats best off the car .......GOOD LOOK......
Old 19-04-2008, 09:11 PM
nuttynil
RS nutta
nuttynil's Avatar
Try a good quality set of moles good teeth or straight nose ones with good teeth and some heat ,u gonna be better with this off and in a bench vice or try locking it in the vice with some wd40 and heat ..good luck
Old 19-04-2008, 09:27 PM
magic randy
magic randy's Avatar
stud extractors mate, take it to a garage mate, cost you a tenner and they might even have a nipple for you
Old 19-04-2008, 09:29 PM
Rick
Rick's Avatar
i had this happen once - in the end got another caliper for pea nuts. Good Luck.
morg65
Escort MK 5 / MK 6
17
11-09-2015 08:40 PM
kevin36
09-09-2015 11:12 AM
markk
09-09-2015 08:11 AM
kevin36
08-09-2015 12:23 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Bleeding the brakes on saff?UPDATE!!bleed nipple is completley rounded off HELP!!??
