Converting XR4x4 to RWD
Old 20-06-2006, 09:34 AM
Cord *
Cord *'s Avatar
Default Converting XR4x4 to RWD
Can anybody tell me how big a job it is to convert the 4x4 to rwd? And what parts I may need and where best to source them?
I'm after a cheap rwd car to go playing in and have dropped on a dirt cheap xr4x4.
Old 20-06-2006, 03:34 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Wouldn't have thought it'd be too hard, but I'm not the best person to ask
Old 20-06-2006, 04:53 PM
sailorbob
sailorbob's Avatar
Here goes something to start you off;
T5 gearbox (I know, obvious )
2wd propshaft
2wd sump
front hubs
Old 20-06-2006, 05:35 PM
costina
Live long and prosper!!
costina's Avatar
cheapest is type 9 box and prop(xr4i)
2 litre sierra front struts
granada 2.9 sump mk3
happy sideways
Old 22-06-2006, 01:21 PM
dojj
Resident Wrestling Legend
dojj's Avatar
all you need is the gearbox and prop
you can keep the front of the stuff on the car as the offsets are different on the xr cars to the 2wd cars and the cossie 4wd cars so you need to think about struts, arbs, brakes, etc because they won't fit
put in a 2wd box with the V6 bellhousing and a normal 2wd prop and away you go
Old 22-06-2006, 02:22 PM
costina
costina's Avatar
But how will the bearings on hubs be retained without shafts
Old 22-06-2006, 02:48 PM
sailorbob
sailorbob's Avatar
I was thinking this. Convert the front shafts to stub axles?
Old 22-06-2006, 03:36 PM
dojj
dojj's Avatar
why do you need the shafts on the front?
you need them to hold the oil in the diff in place
so you remove the shafts, drain the oil, job done
why do you need to pull the stub axles out to pul the shafts out? it's just a circlip (a quick search of front driveshafts should pull up the question posed only the other day about someone (i think it was ian maic) who's posted up pics about them
if you faff about with the front hubs you need to change the brakes because the offsets are differnt, you need to change the struts because they are thinker on the 4wd cars, you need to change the tca,s because they are different, you need to change the arb because thats differnt, then you have the crossmember, steering rack, steering shaft, etc ,etc
so, you still want to go through all of that and STILL have to source a 2.9 sump and crossmember etc?
Old 25-06-2006, 01:00 PM
Cord *
Cord *'s Avatar
Thanks,
I think!!!
turbotrev
39
17-04-2016 09:03 PM
mondeomark
28-09-2015 06:28 AM
jonnyenglish
21-09-2015 07:31 AM
Neil Clark
08-09-2015 07:06 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: Converting XR4x4 to RWD
