Ford Puma Discuss the Ford Puma here!
Ford Puma
Old Jan 9, 2011 | 01:31 AM
JamiePuma's Avatar
JamiePuma
Default Ford Puma
Hey all, i hope this is the right place to put my Ford Puma.
This is the 3rd Ford i have had.
I was wondering how i would go about modifying it, i understand the basics of modifying an engine but i never got along with the Ford MAF sensor.
I know those Ebay resistors dont do nothing, but is there anything i can do to remove it?
I always start with the induction side, then exhaust then cams and so on.
Can anyone help me with improving the induction on my Puma
Thanks
Old Jan 9, 2011 | 02:19 AM
JamiePuma's Avatar
JamiePuma
Also, has anyone got any pictures of a lowered Puma from 30-40-50-60-70mm?
Iv seen lowering springs on Ebay which are 75/50.
I plan on keeping 15s with 195 50 15. But will be 75mm on the front be to low?
Old Jan 9, 2011 | 06:57 AM
bythomson's Avatar
bythomson
warren penalver has a puma cos that may give you some ideas on the exterior, i also remember reading an article few years ago on a hill climb puma that was an awesome looking car
what colour is your car
maybe a set of comps, and a slight drop
think its a fiesta shell with coupe body so most running gear should be the same
http://commons.wikimedia.org/wiki/Fi...ar_Group_B.jpg
http://www.brianomahony.com/puma_sup..._rally_car.htm
Old Jan 9, 2011 | 11:29 AM
Dal_'s Avatar
Dal_
One of our members did an excellent guide to modifying a Puma on my forum:
http://www.projectpuma.com/viewtopic.php?f=51&t=6303
Good luck
Old Jan 9, 2011 | 05:00 PM
JamiePuma's Avatar
JamiePuma
Cheers for that guys, but unfortunitly not much on the old MAF, if its removed, doesnt the engine know its removed/broke and run it at a set setting? And after reading that modifying guide im tempted by the 1.6/1.7 inlet manifold BUT being alloy it would get more heat soak than plastic. Does anyone have any pictures of modified engines? Iv seen this 4bar standard FPR, so no need to add any more in the bay, im just thinking if it will improve low end performance?
That would be great.
Thanks all.
Old Jan 10, 2011 | 06:54 PM
bouncy's Avatar
bouncy
Thanks all.
Puma 1.7 Turbo pic for you!!
Old Jan 17, 2011 | 11:59 AM
JamiePuma's Avatar
JamiePuma
Thats rather sexual lol, il have to stick with the 1.4 for now. But there is always room for improvement..
Are there any cheap bolt on upgrades for the 1.4?
Old Jan 19, 2011 | 12:37 PM
PumaJon's Avatar
PumaJon
Hi All, another Puma boy here, in the process of squeezing a set of ST150 seats in it (front and back) so should be the only 5 seat Puma around. I'll post some pics when its finished.
Old Jan 19, 2011 | 01:06 PM
Dal_'s Avatar
Dal_
Are you going to add extra anchoring points for the 5th middle seat then?
Have fun explaining that to your insurers.. lol
Old Jan 19, 2011 | 01:22 PM
PumaJon's Avatar
PumaJon
Reason I went for the newer seats is the middle reel is integrated into the seat back, will use the chassis mount point for the twin stork.
Checked with Flux before starting, and they said as long as I tell them that the seating capacity has changed so they can update the policy no problem and no extra charge or testing required!!
Been taking pics along the way so I'll do a project thread on your forum if it works out (I'm JonB there).
Ben26
Aug 27, 2015 08:56 PM
borboyous
Aug 22, 2015 11:17 AM
Ben26
Aug 11, 2015 04:19 PM
Aug 10, 2015 12:08 PM
