ST24 Remapping,worth it or not anyone had it done?
Old 27-11-2007, 04:18 PM
sandman666
sandman666's Avatar
Default ST24 Remapping,worth it or not anyone had it done?
Getting quite a varied response to whether its worth having my ST24 remapped or not.some say its not worth it as the power and performance gains will be hardly noticable,others say its worth it and have had it done and can notice a difference.I would like some real help on this as i was thinking of booking it in at Motorsports Developments(OF COARSE) and getting it done by the lads.SOME PROFFESIONAL HELP AND ADVICE WOULD BE GRATEFULLY RECIEVED AND APPRECIATED.
> CURRENT MODS ARE= Huge stainless Cosworth air filter,large bore induction kit,larger modified throttle body,full stainless exhaust with decat,two direct cold air feeds 1 from pipe other from bonnet scoop...HOPE THIS INFO HELPS.
Old 28-11-2007, 08:41 AM
bookwyse
bookwyse's Avatar
The filter and throttle body will aid air intake and the decat will help with the exhaust gases. People have been known to gain from having a chip with only these mods to help sort the fuelling out. But in most cases the standard ECU will sort it out adequetly.
Its up to you if you want to spend the money but dont expect too many gains from those changes. The best way forward would be to get hold of an ST200 upper and lower inlet manifold to really sort the intake out.
Jeff
Old 28-11-2007, 06:45 PM
Wardy257
Wardy257's Avatar
A proper remap would help but a chip is just a bodge.
Old 30-11-2007, 05:00 PM
It depends a lot on ones defintion of "worth".
If your fuelling etc were perfect(for max power) you would not see any gains for a lot of money, if as is very likely they no longer are perfect for max power, as ford do not write programs this way you could see a very noticeable gain certainly in driveability, may only be 10 bhp(example) but is it worth the outlay, that is up to you and your wallet.
Old 30-11-2007, 11:41 PM
paul evo
paul evo's Avatar
there is some one braking a st200 on ebay if u wanna get the upper and lowers of him in doncaster area me thinks it was
Old 26-01-2008, 08:01 PM
STEVEST24
ST by Name and by Nature
STEVEST24's Avatar
Hi,
You doing it the right way, having done most of the mods to get most out of the ST24. I have BLUEFIN on mine and it did improve the driveability, but you won't see any top end improvement. Dreamscience also do a plug in map, which has 3 levels of tune, bit better than BLUEFIN, but the best is always a dedicated map to your car, as all ST24s are not the same, and as you have done most of the main mods, you will benefit.
When I got my BLUEFIN years back, Dreamscience weren't around, but they are quite big now. What I liked about the BLUEFIN was you can set it back to original settings when you want and it will also show you ECU fault codes, but depends what you want.
01-11-2015 06:53 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
gcfcos
59
06-10-2015 05:04 PM
Oranoco
12
02-10-2015 02:18 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: ST24 Remapping,worth it or not anyone had it done?
