Focus st dyno / ABS issues
Old Jun 1, 2014 | 08:03 PM
steve-26's Avatar
steve-26
Default Focus st dyno / ABS issues
Evening all, I tried to run my ST 225 on some rollers at Santa pod today but experienced probs with the abs cutting in and killing the power! I tried turning off traction control and also removing abs fuses but all this did was cause starting problems.
Can anyone tell me how to get round this?
Old Jun 2, 2014 | 06:52 PM
steve-26's Avatar
steve-26
Anyone?
Old Jun 2, 2014 | 07:33 PM
chris cdti's Avatar
chris cdti
you will need to get it plugged in and see what the abs/esp module is saying. Then you will know where to start.
Old Jun 3, 2014 | 11:53 AM
Jago's Avatar
Jago
starting problems sounds odd???
can you try to explain a little more ?
Old Jun 3, 2014 | 12:52 PM
steve-26's Avatar
steve-26
Cheers for replies. First attempt on dyno was with tc turned off when that didn't work they tried pulling the abs fuses still with no luck. After this I went round site and spoke to a chap on a rs owners stand who said he had seen this before on a dyno day and to sort it I needed to pull the three fuses and go for a drive as this tricks the ecu into turning off abs! It didn't all it did was (with three fuses out) kill all power to ignition system, (with two out) restore power to dash but would not turn over. All three in car works fine. Cheers for your help.
Old Jun 3, 2014 | 02:18 PM
t230's Avatar
t230
i had to have my focus diagnosed by 3 mechanics before the third on actually bothered to jACK up the car and spin wheels to properly diagnose (similar abs problem) - my point even if you plug it in doesent always properly diagnosed fault...track back your steps of any repairs that were undertaken ie ...did u change sensors? etc etc...
Old Jun 3, 2014 | 02:49 PM
Jago's Avatar
Jago
like said, could be a faulty ABS sensor.
have you had your tyres changed recently too ? its been mentioned on other forums that having a tyre/tyres changed can cause it to throw a wobbly.
is there anything that comes up on the dash to state there is an issue that has been logged?
the only thing i can think of with regards to removing fuses would be the KAM fuse pull method.... pull out fuse 26 for 30mins or more to reset the ecu and clear any fault codes, then pop it back in and fire her up.
do you have any issues with normal steady..lol road driving ?
Old Jun 3, 2014 | 06:35 PM
botters's Avatar
botters
competant bodger
Originally Posted by Jay,
you need to pull the kam fuse to run these on a a dyno You would think the dyno operator would know this bit mtech are fuckin idiots
made me do a proper lol that
Old Jun 3, 2014 | 07:20 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you don't pull a fuse, it's a relay or soemthing you have to disable to run on the rollers else the esp/tc will throw a wobbly
it's under the bonnet from what i can rememeber but that probably doesn't help a lot
you will also have a light on when you put it back in again, but that normally just resets itself once you've driven it around a bit to tell the system it's working as it should be
Old Jun 4, 2014 | 08:14 PM
steve-26's Avatar
steve-26
Jay do I need to do anything else as we'll as pulling cam fuse? Ie take car for drive after pulling fuse to trick the ecu? Cheers
Old Jun 8, 2014 | 08:24 PM
locum8's Avatar
locum8
Last time mine was on the dyno I had to pull the abs fuse as the Tc kept kicking in But didn't have any problems. I don't mean to insult you but are you pulling the right fuse as when you pulled some you lost ignition etc so they don't sound like abs fuses. Could your manual be for a different model?
Also how may are you taking out as when I done mine I only removed 1.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
gingeRS
Sep 4, 2015 06:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Sep 3, 2015 10:49 AM
