focus 1.4 zetec help
Old Aug 5, 2010 | 07:53 PM
koiman's Avatar
koiman
Default focus 1.4 zetec help
hi i have just fitted my head back on car after belt slipped bending every valve anyway rebuilt running but missing a bit its ok wen i apply gas but on tick over it goes up and down help plz
Old Aug 5, 2010 | 09:15 PM
TomEbbs's Avatar
TomEbbs
As in the revs rise and fall?
If so sounds like a sensor.. Idle control valve (under the inlet on the front) is a common fault on focus's. Take it out and clean it out or replace (they are about £20 i think on ebay)
Old Aug 6, 2010 | 02:05 AM
koiman's Avatar
koiman
hi thanks for reply will have a go at that
Old Aug 6, 2010 | 08:04 AM
TomEbbs's Avatar
TomEbbs
Oviously I'm assuming it's been built right eg timing and what not.
Old Aug 6, 2010 | 09:06 PM
koiman's Avatar
koiman
hi yes timming was set right with the tools for it.the engine starts first time and wen it revs above 1100 it does not mis, the sensers were ok before rebuild,the head was skimmed all valves replaced and 3 guides 4 shims new belt tenisoner
chris
Old Aug 10, 2010 | 12:40 PM
martysmartie's Avatar
martysmartie
Most likely a air leak, especially as you have rebuilt spray WD40 around the inlet manifold with engine running and see if this changes it, if so then there is a sealing problem. If it is being raised by the ISCV then it is being told to do so.
Martin
TPM961
Jan 15, 2018 10:50 AM
JamboRS
28
Sep 14, 2015 09:02 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
