Focus 1.6 Engine Problems
Old Dec 14, 2006 | 06:10 PM
chris1668's Avatar
chris1668
Default Focus 1.6 Engine Problems
just recently blown my engine (just as good as) in my ford focus 1.6 zetec-s which had 80,000 millage, as i didnt fill up my oil level in time and bent the crank so i part ex my engine with a mate from his local garage and got new engine out of a wrote off car, only done 25,000 out of a y reg. focus but as its in my car it seems not to have the power it used to have, seems flat, also just fitted a ripspeed induction kit, seems a little better but still aint happy with it, i filled the oil level up and went a little over so its been burning away the excess oil , its just over now but would that affect the car at all, my mate said run some red ex so it cleans the injectors, and also it seems to be drinking petrol compared to my old engine could any1 help me out
chris
Old Dec 15, 2006 | 09:46 AM
Wardy257's Avatar
Wardy257
Either the new engine has a different version of some of the sensor which are giving the ECU false readings. Or, one or more of the sensors are not connected up properly. Check all the wiring and connections and fault test the sensors. There is a guide here:
http://forum.fordsierraclub.co.uk/viewtopic.php?t=18853
Old Dec 27, 2006 | 06:13 PM
johnny99's Avatar
johnny99
Crank position sensor gives a little trouble on these. About 30 Euro over here.
John
Old Dec 27, 2006 | 06:51 PM
Wardy257's Avatar
Wardy257
There is a guide to checking the CPS in the link I posted above. They only really give trouble when they get dirty.
Old Feb 4, 2007 | 03:59 PM
chris1668's Avatar
chris1668
sensers all seem to be fine, the engine seems to be running better as its been run in a little, not as bad on petrol, when i accerate the car jumps i never really paided much attention 2 it till now, will that just be the spark plugs
also just changed a back wheel bearing as it collapsed inside the wheel drum on weekend works a treat now
Old Feb 5, 2007 | 09:12 AM
watson's Avatar
watson
I would say give it a good service new plugs and oil filter etc then run injector cleaner through the engine then give it a good blast to clear out the shit.
Old Feb 5, 2007 | 01:54 PM
chris1668's Avatar
chris1668
with the new engine its just had a new oil filter ect, if thats the case i might have to do that, i checked oil level, ran stp injector treatment through , its had red ex as soon as i picked up the car while ago, all i can think of is spark plugs or maybe i aint looking hard enough
Old Feb 6, 2007 | 11:13 AM
watson's Avatar
watson
Well change your plugs and make sure you give it a good run up the motorway taking it to higher revs than you normaly would to open all the valves fully.
Has the engine been sat for a while?
Old Feb 9, 2007 | 06:20 AM
All the sensors work on the same(5volts) reference signal.
With the excess oil you may have killed blocked the cat, they are not tollerant of this kind of thing.
In first instance check all sensord actually plugged in, reset KAM, clean MAF.
The holes in the CAT are less than 1mm in size, so you will almost certainly be looking at a new cat.
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
taylora1409
Aug 12, 2015 12:06 PM
