what would u suggest to have done(headwork)
i am in the process of stickinga focus rs lump in a focus,
and im thinking while i got the engine out i may as well have some head work done , any suggestions on what to have done and where local to hertfordshire is the best place to have it done
Oooooh hell no, don't be doing that. The MTX75 box is pretty strong, but the FRS gearbox has uprated internals. Runs with revised gear ratio's, AP clutch and a quick shift. Loads of other niggly bits, but its built to take the strain.
Are you keeping the stock wings? As using RS driveshafts and hubs would be too wide. I used ST170 shafts and joints as I wanted to keep the exterior standard-ish, seem to take a lot of punishment so far.
What else do you want to know? PM me with questions, as I think I've had all the teathing problems you could expect from a conversion, and all FRS related problems...
Depends what your needs are. But basically, its a straight swap, but u must be wary of the parts u use, gotta make sure everything is torque friendly. I also seem welded the shell, to make it that bit sturdier!
PM me with questions if u wish...
Re: what would u suggest to have done(headwork)
But it will need to be remapped after that..
What is your budget on modding your engine??
Give Ian a call, his known for building many 550+bhp Zetec engines
01522 877887 or iHowell@anglianwater.co.uk
Or
Rob@SCC maybe closer to you though
01727 867747 or sales@sccperformance.com
Or
Si B
12-09-2015 06:49 AM
