Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
MK1 Focus not starting
Old May 13, 2020 | 11:34 AM
lloyd1964's Avatar
lloyd1964
Default MK1 Focus not starting
Hi all.
First post by a new member.
I have just bought a MK1 Focus(02)1.6 Zetec SE with genuine 61,000mls.
Fr the first 2 weeks it ran perfectly, no missing or rough tick over etc.
I parked up for 10 minutes, returned and it wouldn't start.
It turned over ok but wouldn't fire up.
I have checked the spark and that seems fine.
My next thought is fuel starvation.
I am going to replace the pump relay.next....is this something you'd recommend or are there any other tests/checks I should do first.
Any advice would be very much appreciated.
Thanks
Lloyd
Old May 13, 2020 | 11:46 AM
focusv8's Avatar
focusv8
You need to get a code reader to see if any errors show.
Guessing and fitting parts can get expensive.
Coilpacks are a popular failure item.
Old May 13, 2020 | 11:53 AM
st220kyle's Avatar
st220kyle
Code reader first as said,
check if you are getting fuel first before changing relay. You should be able to hear the fuel pump priming when turning ignition on. This will rule out relay if you can hear it.
Old May 13, 2020 | 12:03 PM
lloyd1964's Avatar
lloyd1964
Thanks for your replies.
I can't hear the pump priming.
Old May 13, 2020 | 01:51 PM
lloyd1964's Avatar
lloyd1964
Hi
I just got a pal to listen under the tank and then turned ignition on.
He heard(for a split second)what he described as a buzzing/humming sound.
Does this sound like the pump priming?
Old May 13, 2020 | 03:42 PM
st220kyle's Avatar
st220kyle
Yes it does sound like it's priming, you can normally hear this clearly sat inside the car though.
this would rule out pump relay and wiring, but your problem could still be a handful of other things.
Really need the codes reading with a decent reader
Old May 13, 2020 | 03:55 PM
lloyd1964's Avatar
lloyd1964
Just removed a couple of plugs that were quite sooty in appearance and there was a strong smell of fuel.....I'll replace plugs whilst they are out and try to get a mobile mechanic with a code reader.
Cheers for your help.
Old May 17, 2022 | 07:39 PM
Emjaydee's Avatar
Emjaydee
Hi,
Did you manage to fix the problem?
thanks
For only rough drivers
Feb 15, 2018 10:18 AM
woolford
Ford Focus RS Parts for Sale.
Dec 28, 2011 03:07 PM
l0ubie
Jun 10, 2011 05:48 PM
