My RST Rear Suspension Setup! a few pic's!
Old 27-06-2005, 08:28 PM
Andy-R
Andy-R's Avatar
Default My RST Rear Suspension Setup! a few pic's!
1stly a HUGE big up to Tony(NUTS RuS) & Martin(MEFmotorsport) for supplying the rear droplink thank you
2ndly a Big thanks to AVA for fitting/customising everything and getting it all to work together right, fabrication of new suspension turrets(not pictured) plumbing in the brakelines making brake brackets etc etc Cheers Lads
Pic showing Brembo calipers (a la Mitsi Evo) 328mm crossdrilled and vented godspeed disk, these previously having been on the front of the car.
For more info on MEF Droplink (transverse & trailing arms) see the following post
https://passionford.com/forum/viewtopic.php?t=107112
Old 27-06-2005, 08:32 PM
tonyturbo
tonyturbo's Avatar
thats a pukka set up. nice work mate.
i saw your car at AVA a while back. it had the 16" oz's on. think it was before you done totb
Old 27-06-2005, 08:48 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Looks minted Andy, should of wiped it down with a rag you non bufty
btw, i noticed this. . is it some sort of sensor for something? (the black wire attatched to a bracket? top right. looks to be bolted onto the top bolt of the coilover where it's bolted to the hub!
Old 27-06-2005, 09:18 PM
Tim
Tim's Avatar
Looks mint andy
speedo I would say pal
Old 27-06-2005, 09:46 PM
adamS2RST
adamS2RST's Avatar
Andy, How do those rear link arms stay put in the rear hubs? example in the above pic quoted by Dave....They dont seem to go right through the hole?
Looks like a trick fooking setup mate
Old 27-06-2005, 09:54 PM
Andy-R
Andy-R's Avatar
Cheers lads!
tonyturbo yeah that would have been right, there's been a few changes since then!
Dave as per Tim's reply it is the sensor for the speedo, I ordered the wire a little longer so the speedo could be ran off the rear wheel, means that the 0-60 1/4mile time's are as accurate as possible.
Tim cheers bud, appreciated
Old 27-06-2005, 10:05 PM
Andy-R
Andy-R's Avatar
I had to think about that one Adam
They are solid nylon bushes as opposed to rose joints!
Old 27-06-2005, 10:14 PM
scort
scort's Avatar
Is it road legal?
Wheres the handbrake?
Steve
Old 27-06-2005, 10:19 PM
Steven_RW
Steven_RW's Avatar
Man that looks like a SERIOUS piece of kit
Wonder if we can beat 1:03.42 round knockhill when its all up and running
I bet we can
RW
Old 27-06-2005, 10:26 PM
adamS2RST
adamS2RST's Avatar
OK! cool
Old 27-06-2005, 10:52 PM
rapidcossie
rapidcossie's Avatar
looking tops andy!
Old 27-06-2005, 11:54 PM
RANJ
RANJ's Avatar
propper
Old 27-06-2005, 11:58 PM
NUTS RuS
NUTS RuS's Avatar
Good to see it on its new home Andy
This weekend should be a good one for testing it all out proper
AVA
Old 28-06-2005, 04:28 AM
T28 RST
Ok then
T28 RST's Avatar
Looking good Andy
But Dave was right you could have cleaned it for the pics
Old 28-06-2005, 12:00 PM
Dan
Dan's Avatar
Looks well trick mate, liking it! Hope it works as good as it looks, sure it will!
Old 28-06-2005, 12:17 PM
nigel b
nigel b's Avatar
looks good andy
what setting have you gone for camber/castor/toe?
Old 28-06-2005, 12:24 PM
vroooom ptssssh
It Wasnt Me!
aaah the speedo! nice
Old 28-06-2005, 08:30 PM
JamboRS
focus rs 1672
JamboRS's Avatar
you know what i always say about this car andy
FUCKIN AWESOME
Old 28-06-2005, 09:47 PM
Old 29-06-2005, 11:13 AM
Stoo
Stoo's Avatar
Nice one Andy you now have the same set up as me!
I wish! The beast is looking as good as ever
Old 29-06-2005, 01:12 PM
CasperR
CasperR's Avatar
Looks very cool
Must handle like a dream compared to a standard rst
Old 29-06-2005, 02:53 PM
Andy-R
Andy-R's Avatar
Cheers for all the kind comments! Its appreciated
Nigel the rear settings are as follows;
-1°25mins rear camber
+0°12mins toe
Front
-1°20mins camber
+2°40mins caster
+0°08 Toe
Nigel I believe the above to be fairly neutral settings(biased towards straightline stability), things will be tweeked a little here and there untill setup is the way i want.
HTH's
Old 30-06-2005, 10:10 PM
nigel b
nigel b's Avatar
+0°12mins toe
Front
-1°20mins camber
+2°40mins caster
+0°08 Toe
HTH's
cheers andy
very near what ive got
gonna be getting mine tweaked again soon hopefully
Old 01-07-2005, 04:47 PM
Micky
Micky's Avatar
Andy(B8),will youre car be on track at Nat Day at Donnington as Id love to get a closer look at youre set up??Regards Micky
Old 02-07-2005, 07:37 AM
Andy-R
Andy-R's Avatar
Unfortunatly not Micky, I had a bit of misfortune last week and 1 of the new valves that was suplied to my engine builder failed, part of the valve head dropping into the bottom end, destroying the engine.
Ive had to cancel both Croft & National Day as a result....you could say im a little gutted, but hey shit happens!
Your more than welcome to have an indepth look once its back on the road and in working order.
Old 02-07-2005, 07:47 AM
NUTS RuS
NUTS RuS's Avatar
Andy - you still going to Croft ?
Gutted about the engine but if you need to feel how the suspension set up feels on track I know of another way
Old 02-07-2005, 07:50 AM
Andy-R
Andy-R's Avatar
Ill be there later today Tony! Catch up with you either tonight or tomorrow
Old 02-07-2005, 08:23 AM
NUTS RuS
NUTS RuS's Avatar
Old 02-07-2005, 09:34 AM
DazC
DazC's Avatar
Fook!
Old 14-12-2005, 08:06 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Hmm Old post i know, but i just found it
Looking Smart Andy
Just taken note on this little lot
+0°12mins toe
Front
-1°20mins camber
+2°40mins caster
+0°08 Toe
Radders
Old 14-12-2005, 08:34 PM
Oranoco
Oranoco's Avatar
Loving it. Are they ERST front discs that you have made fit?
Old 14-12-2005, 09:38 PM
Andy-R
Andy-R's Avatar
The rears are or were part of the Godspeed 308mm conversion, dont quote me on the front disk size but Im pretty sure they are 354mm. The Calipers front & rear are from an EVO.
Old 14-12-2005, 10:46 PM
Red16
Red16's Avatar
Default Re: My RST Rear Suspension Setup! a few pic's!
great set up you got here
any chance of a few pics of the rear suspension turrets ?
Old 14-12-2005, 10:58 PM
Charlie Chalk
Unknown.
Im having my rear turrets done when my shell ( finially goes in ) , Will get some pictures up on completition
Old 14-12-2005, 11:12 PM
Red16
Red16's Avatar
Freddy_mercury_magic
Old 14-12-2005, 11:16 PM
NUTS RuS
NUTS RuS's Avatar
Red16
Yours will be finished, abused and possibly scrapped well before then mate
Old 14-12-2005, 11:19 PM
Red16
Red16's Avatar
Originally Posted by NUTS RuS
Red16
dunno how to take that, is my driving that bad or is radders that slow
Old 14-12-2005, 11:40 PM
Charlie Chalk
Unknown.
I think Tonys taken the piss out my project
Its FOREVER going
Old 15-12-2005, 12:24 AM
Red16
Red16's Avatar
Its FOREVER going
thought so
Old 15-12-2005, 06:39 AM
NUTS RuS
NUTS RuS's Avatar
Quick Reply: My RST Rear Suspension Setup! a few pic's!
