please please please help me with rising revs
hi guys, i have had a good look on this forum but cant seem to find what im looking for......
when i start my car from cold she ticks over fine , then as she gets warmer the revs seems to rise , after 5 miles of driving the revs are sitting at over 3000 . its annoying the whole street and me also. if i turn the car off at this piont it wont start again for at least an hour , sometimes it will start right away sometimes it wont .
it seems to get worse when the engines warmer . and sometimes the btrake pedal goes rock solid. always when the revs are high .
please help me people , i dont know what to do, i can only say that i ''think'' it might be a split pipe somewhere ???
mucho thanky in advance. PS . WOULD A DEAD BATTERY MAKE IT DO THIS ??
![](https://i4.photobucket.com/albums/y137/harrybaggit/34_1_b.jpg)
Might be something wrong with your vacuum (brake master cilinder??), because you say the brake pedal is getting rock hard.
I would check all the vacuum lines first if 1 of them is torn or damaged in another way.
By the way that is a great van you own
Cheers.
Cheers.
well the cars now off the road i will report what it was when its fixed , i cant drive it n`more ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
edit edit:: ive been messing about with all the plugs and so on, i got a new battery too, seems to be ''ok'' for the time being , i let her run until the fans came on , then she started ok and the revs are fine and tickovers back to normal, even when hot and after a blast![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
lets wait and see ..........
its not that , i checked it , i think it could be servo master cylinder related , but then having said that when i started her up this morn as soon as i tiokk off the cold start plug it was fine, plug it back in and went loopy again, ill sort it eventually......
no its still with me jano , the day i was fixing to come see you it played up big time then my battery died, it seems ok now, im getting a new servo/master cylinder at the weekend so should have that on mid week.........thanks for helping tho mate , i do appreciate it
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
